[mapguide-users] Error with loading shp in MG studio
Swati Prabhu swatip at bonair.stanford.edu
Fri Aug 4 12:46:17 EDT 2006
Hi Tom,
Thank you for the response. I tried your suggestion and imported the file
successfully into Access. These shape files are a copy of the files used by
Mapguide 6.5. Just to eliminate some corruption of the shx files, I did try
exporting a brand new shape file from autocad 2006 for MG studio and it too
continues to have problems.
Thanks
Swati
I
Content-Type: text/plain;
         charset="us-ascii"
Date: Fri, 4 Aug 2006 07:57:31 -0700
From: Tom Fukushima <tom.fukushima at autodesk.com>
Subject: [mapguide-users] Error with loading shp in MG studio
Hi Swati,
We noticed a problem with loading SHP files when the .dbf file has
multiple columns with the same name.
One way to check if this is the case is to try to import the .dbf into
Access. In MS Access: 1) create a new blank db, 2) File > Get External
Data > Import..., 3) select the dBase filter in the "Files of type" drop
down, then 4) select your .dbf file and press Import.
An error that states "The Microsoft Jet database engine could not find
the object 'xyz.dbf'.  Make sure the object exists and that you spell
its name and the path name correctly" should come up.
Could you try the above and see if the same thing happens with your .dbf
files?
Thanks
Tom
Swati Prabhu,
Facilities Operations - Maps and Records
Stanford University
Phone: 650 723 0988 Fax: 650 723 7095
More information about the Mapguide-users mailing list
