[mapguide-users] BC Albers Projection and other coordsys questions.
BradM masonb at dfo-mpo.gc.ca
Fri Aug 25 17:19:03 EDT 2006
Thanks Gordon, please email to Joy at: jappler at my.bcit.ca thanks !
Gord McKenzie wrote:
> Brad/Joy,
> I have attempted to create your coordinate system in AutoCAD 2007.  The
> coordsys files created should be able to be copied into your
> studio/enterprise install.  They should go into your Program Files\Common
> Files\Autodesk Shared\GIS\Coordsys\11e folder.  I will not post the files
> as
> they are 3-4 mb and my coordsys def might not be right.  I have no way to
> test.  Let me know if you would like them by e-mail and you could back up
> your old ones and try these to see if they work.  I will be happy to make
> modifications if the settings need adjusting.
> BTW, can anyone point me to some resources for working with coordinate
> systems in the open source version.  I know where the proj files are and I
> can see a couple of wkt file from esri and cubewerx that are loaded from
> some kind of include file.  Should I add my own wkt file and set up custom
> coord systems in that file?  Is there mapguide documentation for this that
> I
> am missing?
> Thanks.
View this message in context: http://www.nabble.com/BC-Albers-Projection-and-other-coordsys-questions.-tf2165563.html#a5991483
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users mailing list
