[mapguide-users] Insertation (reference) point of symbols
Tom Fukushima tom.fukushima at autodesk.com
Tue Aug 29 11:31:57 EDT 2006
I've traced this problem down to systems where a "," is used as the decimal point. We should have fixes submitted for this shortly.
In the meantime the techniques used in this thread http://www.nabble.com/ODBC---Successful-connection---FINALLY%21%21%21%21%21%21-tf2026417.html might also solve this problem.
Regards
Tom
-----Original Message-----
Sent: Tuesday, August 29, 2006 8:04 AM
Subject: RE: [mapguide-users] Insertation (reference) point of symbols
I've had this problem too on Windows. On Linux everything is perfect aligned!
-----Oorspronkelijk bericht-----
Van: Ing. Cristian Galdini [mailto:galdini at dek.it]
Verzonden: dinsdag 29 augustus 2006 9:45
Aan: users at mapguide.osgeo.org
Onderwerp: Re: [mapguide-users] Insertation (reference) point of symbols
Hi, i have the same problem,
In my case, the server works fine as an application instead as a service (!)
from prompt "mgserver /interactive"
IBB Ingenieurbüro Battefeld wrote:
> Hi,
> all symbols has offset. It means, in the original drawing (dwg) the
> base point of each block (a simple circle) is the center point. But in
> the viewer each symbol seems to has an offset. The change of the
> reference point in MapGuide Studio is without effect. It's the same if
> I use dwg- or shp-format.
> What could be wrong?
> Thanks in advance - Peter
> P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio
> 1.0.0.17804
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
