[mapguide-users] tuning mapguide performance
Paul Spencer pspencer at dmsolutions.ca
Wed Dec 13 21:32:25 EST 2006
Unless I am mistaken, support servers are kinda broken in the current
releases?  I believe that there are some outstanding issues with
session affinity and load balancing and there is an RFC (?)
discussing possible solutions.
Paul
On 13-Dec-06, at 9:38 AM, Chris Gountanis wrote:
> My guess would be to setup solid servers on a solid connection and run
> support servers. That would give you a cluster of servers that should
> balance the requests I would assume.
> Chris
> Making complex information more accessible.
> -----Original Message-----
> From: Traian Stanev [mailto:traian.stanev at autodesk.com]
> Sent: Wednesday, December 13, 2006 8:14 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] tuning mapguide performance
> Why does the server die? Even if it is overloaded, it should just
> get really
> unresponsive, but not die. Is there some sort of exception that is
> thrown?
> Check the logs. 1000 requests for 10 minutes doesn't sound that
> heavy unless
> the requests are doing something really time-consuming.
> Traian
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Wednesday, December 13, 2006 12:53 AM
> Subject: [mapguide-users] tuning mapguide performance
> Hi all,
> is there a way to improve the mapguide performance?
> As i have try to access to the map and perform some search address
> function by simulating 1000 users are accessing in 10 minutes, the
> mapguide server die. So I need to keep restarting so that users can
> access the map.
> I was wondering how to improve the performance as there might me more
> than 100000 users will access the map.
> Thank you
> Regards,
> Kencana
> http://www.nabble.com/tuning-mapguide-performance-
> tf2812176.html#a784757
> 5
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Mapguide-users mailing list
