Taskframe error: "Session has expired or is invalid."
kruno kruno at ineo.hr
Sat Dec 16 07:24:15 EST 2006
it works after few other corrections!!!
Thanks Willem!!! Your solution was correct!
Willem Schwarte wrote:
> Hi,
> I think it has to do with a problem I have reported earlier:
> In gettingstarted.php there is this line:
> $cred = new MgUserInformation("Administrator", "admin");
> But if you change the default Administrator passwordt, you will get an
> error.. change it to:
> $cred = new MgUserInformation("Anonymous", "");
> Willem Schwarte
> -----Oorspronkelijk bericht-----
> Van: kruno [mailto:kruno at ineo.hr]
> Verzonden: donderdag 14 december 2006 20:07
> Aan: users at mapguide.osgeo.org
> Onderwerp: [mapguide-users] Taskframe error: "Session has expired or is
> invalid."
> Hi,
> i have a problem with the session. Namely, when i try to open a map from
> the
> www, the map is shown but the pages in taskframe (the right frame),
> which
> acquire sessionId, can not be open:
> Session has expired or is invalid. Please log in again.
> Description: An unhandled exception occurred during the execution of the
> current web request. Please review the stack trace for more information
> about the error and where it originated in the code.
> Exception Details: OSGeo.MapGuide.MgSessionExpiredException: Session has
> Source Error:
> Line 34:     siteConnection.Open(userInfo);
> However, everything works fine locally, i.e. on a localhost.
> Conclusively,
> this error only appears when i try to open the map, i.e. the pages in
> the
> taskframe of the mapgude viewer, from www.
> Please help.
> Thanks,
> Kruno.
> http://www.nabble.com/Taskframe-error%3A-%22Session-has-expired-or-is-in
> valid.%22-tf2822804.html#a7879007
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Taskframe-error%3A-%22Session-has-expired-or-is-invalid.%22-tf2822804.html#a7905781
More information about the Mapguide-users mailing list
