[mapguide-users] Re: PLease Help He
sukalyan chakraborty chakraborty.sarkar at gmail.com
Tue Jul 4 01:53:06 EDT 2006
Yes the problem solved now next problem
Resource was not found:
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout Exception
occurred in method MgResourceDefinitionManager.GetDocument at line 483 in
file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
now if i go to load the resource using
http://localhost/mapguide/mapadmin/login.php
Using Administrator & admin as uname & pass
It gives the another error:
*Fatal error*: Call to undefined function MgInitializeWebTier() in *C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\login.php* on line
*68*
Please Help Me Again.
On 7/4/06, Andy Morsell <amorsell at spatialgis.com> wrote:
>  Try adding C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin to your
> Windows path, reboot, and try again.
> Andy
>  *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* Monday, July 03, 2006 10:12 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* SPAM-LOW: [mapguide-users] Re: PLease Help He
>  Hi
> I'm Tll now facing same problems.
> Is there any more solution ???
> I've checked the framework version & keeping the bin folder inside the
> samples
> & also keeping the all dlls open from  the bin folder.
> Inspite of that i'm getting same error.
> On 6/30/06, sukalyan chakraborty <chakraborty.sarkar at gmail.com> wrote:
> >  please help me...
> > When I'm Running pages from MGStudio then it is running fine but
> > If I running like
> > http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
> > or
> > http://localhost/mapguide/dotnetviewersample/dwfviewersample.aspx
> > then getting the error
> >  I'm using Framework v2.0.50727 Server Error in '/mapguide' Application.
> >  *Compilation Error* *Description: *An error occurred during the
> > compilation of a resource required to service this request. Please review
> > the following specific error details and modify your source code
> > appropriately.
> > *Compiler Error Message: *CS0246: The type or namespace name 'OSGeo'
> > could not be found (are you missing a using directive or an assembly
> > reference?)
> > *Source Error:*
> >    Line 17: <%@ Import Namespace="System.Collections" %>
> > Line 18: <%@ Import Namespace="System.IO" %>Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>Line 20: <script language="c#" runat="server">
> > Line 21:
> > *Source File:* c:\Program
> > Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx
> >    *Line:* 19
> > Show Detailed Compiler Output:
> >   C:\WINDOWS\system32> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe" /t:library /utf8output /R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a3a\System.Web.Services.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll" /R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System.Xml.dll" /R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.Data.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a\System.Web.Mobile.dll" /R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll" /R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.Web.dll" /out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.dll" /debug- /optimize+ /win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\3tjlg3zd.res" /w:4 /nowarn:1659;1699  "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.0.cs" "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238.rr15dqlk.1.cs"
> > Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
> > for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
> > Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
> > c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(19,11): error CS0246: The type or namespace name 'OSGeo' could not be found (are you missing a using directive or an assembly reference?)
> > c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,24): error CS0246: The type or namespace name 'MgMap' could not be found (are you missing a using directive or an assembly reference?)
> > c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(39,1): error CS0246: The type or namespace name 'MgLayer' could not be found (are you missing a using directive or an assembly reference?)
> > c:\Program Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityfunctions.aspx(55,26): error CS0246: The type or namespace name 'MgByteReader' could not be found (are you missing a using directive or an assembly reference?)
> > Show Complete Compilation Source:
> >   Line 1:    <%--
> > Line 2:    Copyright (C) 2004-2006  Autodesk, Inc.
> > Line 3:    This library is free software; you can redistribute it and/or
> > Line 4:    modify it under the terms of version 2.1 of the GNU Lesser
> > Line 5:    General Public License as published by the Free Software Foundation.
> > Line 6:
> > Line 7:    This library is distributed in the hope that it will be useful,
> > Line 8:    but WITHOUT ANY WARRANTY; without even the implied warranty of
> > Line 9:    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
> > Line 10:   Lesser General Public License for more details.
> > Line 11:
> > Line 12:   You should have received a copy of the GNU Lesser General Public
> > Line 13:   License along with this library; if not, write to the Free Software
> > Line 14:   Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
> > Line 15:   --%>
> > Line 16:
> > Line 21:
> > Line 22:   NameValueCollection GetParameters()
> > Line 23:   {
> > Line 24:       return Request.HttpMethod == "GET" ? Request.QueryString : Request.Form;
> > Line 25:   }
> > Line 26:
> > Line 27:   void InitializeWebTier()
> > Line 28:   {
> > Line 29:       // Initialize web tier with the site configuration file.  The config
> > Line 30:       // file should be in the same folder as this script.
> > Line 31:       //
> > Line 32:       string realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
> > Line 33:       String configPath =  realPath + "webconfig.ini";
> > Line 34:       MapGuideApi.MgInitializeWebTier(configPath);
> > Line 35:   }
> > Line 36:
> > Line 37:   // Searches the map for a layer with the specified name.
> > Line 38:
> > Line 39:   MgLayer GetLayerByName(MgMap map, String layerName)
> > Line 40:   {
> > Line 41:       MgLayer layer = null;
> > Line 42:       for (int i = 0; i < map.GetLayers().GetCount(); i++)
> > Line 43:       {
> > Line 44:           MgLayer nextLayer = map.GetLayers().GetItem(i);
> > Line 45:           if (nextLayer.GetName() == layerName)
> > Line 46:           {
> > Line 47:               layer = nextLayer;
> > Line 48:               break;
> > Line 49:           }
> > Line 50:       }
> > Line 51:       return layer;
> > Line 52:   }
> > Line 53:
> > Line 54:   // Read the content from an MgByteReader and send it back as the response.
> > Line 55:   void OutputReaderContent(MgByteReader byteReader, HttpResponse response)
> > Line 56:   {
> > Line 57:       MemoryStream memBuf = new MemoryStream();
> > Line 58:
> > Line 59:       byte[] byteBuffer = new byte[1024];
> > Line 60:       int numBytes = byteReader.Read(byteBuffer, 1024);
> > Line 61:       while(numBytes > 0)
> > Line 62:       {
> > Line 63:           memBuf.Write(byteBuffer, 0, numBytes);
> > Line 64:           numBytes = byteReader.Read(byteBuffer, 1024);
> > Line 65:       }
> > Line 66:
> > Line 67:       response.ContentType = byteReader.GetMimeType();
> > Line 68:       byte [] content = memBuf.ToArray();
> > Line 69:       response.OutputStream.Write(content , 0, content.Length);
> > Line 70:   }
> > Line 71:
> > Line 72:   </script>
> > Line 73:
> > *Version Information:* Microsoft .NET Framework Version:2.0.50727.42;
> > ASP.NET <http://asp.net/> Version: 2.0.50727.42
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060704/577c2487/attachment.html
More information about the Mapguide-users mailing list
