[mapguide-users] I can't see views when I use the FDO/ODBC.
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Jul 5 22:40:53 EDT 2006
Ah....I've never heard it called a View before.
Andy Morsell wrote:
> A view is a query definition within the Access database itself.  There are
> several types of views, but in this case, it would be a select view where
> either a single table is filtered or two or more tables are joined on a
> common key.  Views are very common.  They are called Queries in SQL Server
> and Views in Oracle.
> Andy
> -----Original Message-----
> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> Sent: Wednesday, July 05, 2006 2:47 PM
> To: users at mapguide.osgeo.org
> Subject: Re: [mapguide-users] I can't see views when I use the FDO/ODBC.
> What exactly are you trying to look for other than a table? What's a 'view'?
> Do you mean a 'form'? ODBC connections will only let you access tables. No
> forms, no reports, etc....
> Andrew
> Luiz Marcio Viana wrote:
>> Hi,
>> I'm trying to see views in MapGuide Studio, using the FDO/ODBC, but I
>> see only the tables.
>> I'm using the MS Access database and the last versions of MapGuide
>> Open Source and MapGuide Studio Preview.
>> Are there any problem with FDO/ODBC to publish views?
>> I know FDO/ODBC works only with MS Access. Is It right?
>> Thanks,
>> Luiz Marcio
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
