FW: MYSQL MyODBC Studio
Willem Schwarte willem at giskit.nl
Thu Jul 27 05:09:50 EDT 2006
In Studio I now get a list of Datasources available on the server.
Selecting the correct datasource and credentials, gives me a button
"Show Tables". But if clicked, nothing happens...
I tried to set the option = 4 for tracing and Trace = 1 in the odbc.ini,
but no trace log is created.
Does anybody now what might be wrong?
Willem
Van: Dave Wilson [mailto:dave.wilson at autodesk.com]
Verzonden: woensdag 26 juli 2006 18:01
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] FW:
When installing the ODBC driver from the rpm we had the same dependency
issue, but we installed it anyway using a --nodeps parameter.
I just tried this again. I put a single entry into the ODBC.ini file
(using the template from the website and corrected the path to the .so
file) and it worked fine. I didn't need to put anything in the
ODBCinst.ini.
In this case we used the 3.5 driver.
I suspect that the invalid XML is happening because it can't find the
ODBC.ini file.
Dave
Sent: Wednesday, July 26, 2006 6:13 AM
Subject: [mapguide-users] FW:
When installing myODBC on Red HAt 3 ES we get the error below. Does
anybody know what this is and how to resolve this?
We tried bypassing it, but then Studio gives an " invalid XML document
(0,0)"  error when looking for ODBC connections..
Willem
Van: Bas van den Dikkenberg
Verzonden: woensdag 26 juli 2006 14:06
Aan: Willem Schwarte
Onderwerp:
error: Failed dependencies:
        libstdc++.so.6(GLIBCXX_3.4) is needed by
mysql-connector-odbc-3.51.12-1
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060727/0af2eeab/attachment.html
More information about the Mapguide-users mailing list
