[mapguide-users] Is everbody on holiday or something?
Traian Stanev traian.stanev at autodesk.com
Thu Jul 27 09:16:50 EDT 2006
I am not sure about the answer to this so someone should correct me if
I'm wrong... I think only the ODBC provider will let you specify
separate columns for x and y and then will treat that as a point. All
other providers expect the data to have a bona fide geometry property.
The x and y columns in your case are just simple data attributes, and
not geometry.
Traian
  _____
Sent: Tuesday, July 25, 2006 9:36 AM
Subject: RE: [mapguide-users] Is everbody on holiday or something?
Importance: High
Here is what I see in studio when connecting to mysql through Mapserver
Enterprise 2007.
There are X and Y columns, but why can't I choose a geometry? I just
want to create a point layer from a database source, just like I did on
windows with the odbc FDO.
Willem
  _____
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: Tuesday, July 25, 2006 3:26 PM
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Is everbody on holiday or something?
I tried the one that comes with mysql and now I can connect. But in the
list of data stores there is nothing. I'm trying to create one no to
check differences.
Willem
  _____
Verzonden: Tuesday, July 25, 2006 3:15 PM
Does it need to be a specific version? Because I tried one that was
installed with PHP5, but that one gave errors. Another gave also errors.
Willem
  _____
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: Tuesday, July 25, 2006 3:09 PM
You need to copy libmysql.dll to the directory where the provider dll
is, likely under /FDO/bin relative from where acad.exe is located.
Autodesk can't legally distribute MySQL binaries, hence you have to
download it yourself. This should be documented somewhere in the Map
documentation.
Traian
  _____
Sent: Tuesday, July 25, 2006 9:04 AM
Subject: [mapguide-users] Is everbody on holiday or something?
Where is the feedback? Is Autodesk still reading this list?
The MySQL provider does not give me geometry. I have exported the access
database to mysql.
Also could not test connection in Map 2007 because libmysql.dll was not
found?!
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060727/41e99eb1/attachment.html
More information about the Mapguide-users mailing list
