[mapguide-users] Printing to specific scale doesn't work - wrong scale
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jul 27 14:00:07 EDT 2006
Nope....nothing quite so simple unfortunately......also of note, I just
tried to print the same thing out at 1:10666 (which should equal
1:10000, if I did my math right), but that just plain doesn't work...I
get a blank page. I'm guessing that you can't just type in the scale
that you want, unless it's in the list (though the program lets you
think that you can do it)
Andrew
Andy Morsell wrote:
> You don't have any printer specific override settings that might be
> affecting this do you?  Such as a "scale page to fit" or similar option?
> Andy
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Thursday, July 27, 2006 10:46 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Printing to specific scale doesn't work -
> wrong scale
> If you select a printout to be at a specific scale, it's wrong (off by
> about 5%).
> If you are using a custom print layout with a scalebar, it's easier to
> notice right away. Print something at 1:10000, for example. Then grab
> an actual 1:10000 scale and you'll see that the scale bar on the page
> is too small. From 0 to 600 metres, it should measure 60mm, but is
> actually only 56mm. This translates to a 40metre error when scaling
> things off of the printout. The scalebar does actually match the scale
> of the drawing though, but it is not 1:10000, as it claims.
> Has anyone run into this? I've just submitted it as a bug....maybe
> there's a workaround though....
> Andrew
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
