[mapguide-users] Layer Groupings, Andy can you help?
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jun 29 20:32:32 EDT 2006
It's in that winmail.dat file....he must be using Outlook, and you must
not be (neither am I). Check out this page for the solution:
http://www.gpc.edu/~jbenson/resource/winmail.htm
Making those themed layers really isn't too complex though. I'd offer
you some help right now, but I'm home for the night, and don't have
Studio in front of me.
Andrew
kenny at keniginc.com wrote:
> Thanks a lot, Andy.
> I am going over the gettingStarted pdf file as I write this.
> Visually, it would have been great to see the attachment you
> mentioned. It apparently didn't come through.
> Quoting Andy Morsell <amorsell at spatialgis.com>:
>> Those are standard thematic layers created in Studio when defining
>> the layer
>> style.  Attached is a screenshot.  There is also an example in the
>> GettingStartedGuide.pdf that is in the Studio Help folder.  You can also
>> open and examine in Studio the Parcels layer definition, which is
>> themed, in
>> your Sheboygan sample dataset.
>> Andy
>> -----Original Message-----
>> From: kenny at keniginc.com [mailto:kenny at keniginc.com]
>> Sent: Thursday, June 29, 2006 1:27 PM
>> To: users at mapguide.osgeo.org
>> Subject: [mapguide-users] Layer Groupings, Andy can you help?
>> Andy, I see you that you get picked on a lot around here for obvious
>> reasons. Sorry for joining that group.
>> Reason, I am singled you out is I saw on your sampe MG OS app that you
>> grouped Roads into Major and Minor categories.
>> Did you do this programmatically or did you do it through the Studio?
>> Obviously, for me at this stage, I would prefer to do things through the
>> studio until I am very knowledgeable about the architecture.
>>  From what I have read, you use themes to accomplish this but how do
>> I do
>> this?
>> For instance, I have basins that need to be grouped into several sub
>> layers,
>> each with same view extent.
>> Any assistance, including any materials that would make this easy.
>> Thanks for getting me started on MG OS.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
