[mapguide-users] OGR Provider in FC4
Eliot Cline eliot at gospatial.com
Thu Jun 29 21:59:06 EDT 2006
OK. Its working now. I just copied my copy of gdal/geos into the mapguide lib folder and everything worked. Probably better to actually build mgos with the gdal 1.3.2 source? My current build would have used the headers from 1.3.0, so I wonder if my "solution" won't actually create other problems? Anyway, at least I can see that it is possible to make this work.
Thanks again,
Eliot
----- Original Message -----
  Sent: Thursday, June 29, 2006 8:01 PM
  Subject: RE: [mapguide-users] OGR Provider in FC4
  Yeah this one is difficult. For what it's worth, I would have gone the other way around when moving libraries: any library that is already installed in /usr/local, I would have simply deleted from the mapguide directory (things like xerces, libACE, gdal, etc). Come to think of it, MapGuide builds against a copy of gdal 1.3.0 while the provider was written against gdal 1.3.2 and uses function calls that don't exist in 1.3.0. So if it's picking up the wrong gdal at runtime, it will definitely not work. Ouch...
  To work around similar issues on Windows I linked in all required libraries statically into the provider dll, but that's not really an option on Linux.
  Traian
  Sent: Thursday, June 29, 2006 1:21 AM
  Subject: Re: [mapguide-users] OGR Provider in FC4
  Hello Traian,
  Thanks for all your help. So far no joy. I manually created the datasource as per your instructions. After starting Studio, the new resource shows, but when trying to create a layer based on the new data source, I just get the same error as before.
  One thing I noticed is that mgserver was segfaulting on exit. Should have noticed it before, but my eyes aren't so good after years in front of computer screens! I ran mgerver in gdb, let it segfault and ran a backtrace. The odd thing was that the mgserver was loading geos from /usr/local/lib instead of /usr/local/mapguideopensoure/lib. I reconfigured mapguide and saw that although the configure script was looking for gdal in /usr/local/mapguideopensoure/lib it was grabbing geos from /usr/local/lib. I moved my copy of geos to another folder and re-ran config. This time it couldn't find geos at all. After some messing around it compiled OK using the geos included with mgos. Ran the server and it still segfaulted on exit. Back to the drawing board and configured without geos support. After that no more segfault, but still the same problem with the OGR provider.
  My FC4 setup is pretty much straight out of the box except for the upgrade to gcc 4.0.2. pgsql is 8.1.2, postgis 1.1.1, gdal 1.3.2, geos2.2.2, and all are installed in default locations (e.g. /usr/local for everything). I'm stumped on this one.....
  Thanks,
  Eliot Cline
    Sent: Wednesday, June 28, 2006 8:03 PM
    Hi Eliot,
    This error (CLNT_8_UNABLE_TO_LOAD_LIBRARY) shows that MapGuide is trying to load a provider but failing. It can happen either because of missing dependencies (which you don't seem to have), mismatched provider version (which seems ok for you) or because it can't find the symbol "CreateConnection()" in the provider .so. I can't think of another reason it won't load, but I will try compiling it on FC4 and see if it works for me.
    One thing you can try is to manually set up an OGR feature source, using the MapGuide html pages at:
    http://localhost:8008/mapguide/mapagent/index.html
    Edit the attached xml file to have the correct DataSource value (and also fix the Windows-style newlines :-), and then use the SetResource page to upload it to the server. You will need to set the Content field in the SetResource page to that file. After executing the SetResource, you should be able to see this feature source in Studio and create a layer based on it. When you point the new layer to this feature source, it will either succeed or show an error. If it shows an error, it would be a good time to check the log again. Also, if possible, run the server from the command prompt and watch if it prints out any errors or warnings.
    Traian
    Sent: Wednesday, June 28, 2006 12:09 AM
    Hello Traian,
    Thank you for your help. Yes, the compilation went fine for both the MGOS software and relevant components. I had some problems with the mgserver hanging, as well as the "make check" step for compiling the debug profile. Fixed that by upgrading gcc to 4.0.2. My entry in providers.xml is:
      <FeatureProvider>
     <Name>OSGeo.OGR.0.1</Name>
     <DisplayName>FDO Provider forr OGR</DisplayName>
     <Description>Access to OGR data sources</Description>
     <IsManaged>False</IsManaged>
     <Version>0.1.0.0</Version>
     <FeatureDataObjectsVersion>3.0.0.0</FeatureDataObjectsVersion>
     <LibraryPath>/usr/local/fdo-3.0.0/lib/libOGRProvider.so</LibraryPath>
      </FeatureProvider>
    Shape and SDF providers are working fine, but unfornately they are of no use to me. I checked the server error log and there were some messages about FDO. The funny things is that these messages showed up in the log yesterday morning. I have been messing about constantly since then and no more error mesages of any kind have been written to the log since that time. I even changed the name of libOGRProvider.so in providers.xml hoping to force an error of some kind just to see if there was any attempt by the server to actually load the .so file. Here is the message I found in the log:
    <2006-06-27T08:45:14>
     Error: An exception occurred in FDO component.
     StackTrace:
      - MgOpTestFeatureSourceConnection.Execute line 104 file OpTestFeatureSourceConnection.cpp
      - MgFdoConnectionManager.Open line 263 file FdoConnectionManager.cppAn exception occurred in FDO component.
    This is the only error in the log, but is repeated a number of time. Ran ldd - r on libOGRProvider.so and it looks ok, output is below. One other strange thing, that is a little off-topic, is that apache is now spitting a dummy when I try to shut it down with apachectl --stop. It throws this error:
    (98)Address already in use: make_sock: could not bind to address [::]:8008
    no listening sockets available, shutting down
    Unable to open logs
    The only thing listening to 8008 is apache, so I don't get this one at all. All was well until I upgraded gcc. Don't know if it is related or not, but if anybody has seen this and knows how to fix it, please let me know.
    Regards,
    Eliot Cline
    Below is the output of ldd -r libOGRProvider.so
     linux-gate.so.1 =>  (0x003e3000)
     libFdo.so.3 => /usr/local/fdo-3.0.0/lib/libFdo.so.3 (0x00516000)
     libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x00bb2000)
     libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00185000)
     libm.so.6 => /lib/libm.so.6 (0x00111000)
     libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00135000)
     libc.so.6 => /lib/libc.so.6 (0x00264000)
     libxalan-c.so => /usr/local/fdo-3.0.0/lib/libxalan-c.so (0x00f13000)
     libxalanMsg.so.17 => /usr/local/fdo-3.0.0/lib/libxalanMsg.so.17 (0x0013f000)
     libxerces-c.so.25 => /usr/local/fdo-3.0.0/lib/libxerces-c.so.25 (0x07cbc000)
     libpthread.so.0 => /lib/libpthread.so.0 (0x00147000)
     libdl.so.2 => /lib/libdl.so.2 (0x00159000)
     libgeos.so.2 => /usr/local/lib/libgeos.so.2 (0x008a3000)
     libungif.so.4 => /usr/lib/libungif.so.4 (0x0015d000)
     libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00165000)
     libtiff.so.3 => /usr/lib/libtiff.so.3 (0x0038e000)
     libpng12.so.0 => /usr/lib/libpng12.so.0 (0x003e4000)
     libpq.so.4 => /usr/local/pgsql/lib/libpq.so.4 (0x00408000)
     libz.so.1 => /usr/lib/libz.so.1 (0x0041f000)
     librt.so.1 => /lib/librt.so.1 (0x00432000)
     /lib/ld-linux.so.2 (0x00b96000)
     libSM.so.6 => /usr/X11R6/lib/libSM.so.6 (0x00a61000)
     libICE.so.6 => /usr/X11R6/lib/libICE.so.6 (0x00446000)
     libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x00a6a000)
     libcrypt.so.1 => /lib/libcrypt.so.1 (0x00460000)
     libresolv.so.2 => /lib/libresolv.so.2 (0x0048e000)
     libnsl.so.1 => /lib/libnsl.so.1 (0x004a1000)
      Sent: Tuesday, June 27, 2006 7:44 PM
      It could be several things causing this. I assume you compiled and installed the provider successfully (by adding an entry to providers.xml), since you get a Data Connection page for it in Studio. One thing I would check is whether the libOGRProvider.so has missing dependencies (by running ldd -r on it). Also check the MapGuide server error log for any Fdo exceptions -- there should be a message if it can't even create a connection to OGR. If you run the server from a command line (using /interactive), you will also be able to see the exceptions printed on the console (the OGR provider may also print some debug information to the console that you won't see in the logs). Also make sure the FDO version listed in providers.xml entry for OGR matches the versions listed for the other providers (there are some overzealous version checks in the 1.0 code).
      Traian
      Sent: Tuesday, June 27, 2006 12:03 AM
      Subject: [mapguide-users] OGR Provider in FC4
      I just got MGOS up and running today on Fedora Core 4. I am trying to use the OGR provider to access data in PostgreSQL. When I try to create a new data connection in Studio, the connection properties section is blank. No "DataSource" or "ReadOnly" properties showing. Any help would be appreciated.
      Thanks,
      Eliot Cline
    To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
    For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060630/44a42ad2/attachment.html
More information about the Mapguide-users mailing list
