[mapguide-users] Using Project Tracker instead?
Robert Bray robert.bray at autodesk.com
Sun Mar 12 18:25:17 EST 2006
Andy,
Anyone can use Project Tracker. I would definitely encourage users and
application developers to use it to log defects and enhancement
requests. If you are at all in doubt, ask on the list about the issue
first. We can discuss it and then decide if it should be logged or not.
For now, please continue to send Studio related defects and enhancement
requests to the list.
Bob
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Sunday, March 12, 2006 4:17 PM
Subject: [mapguide-users] Using Project Tracker instead?
Bob,
I was assuming that the Project Tracker was for the development team
rather than end user bug and wishlist submission.  Should we be entering
issues directly into there instead of submitting them to the users list?
Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Robert Bray [mailto:robert.bray at autodesk.com]
Sent: Sunday, March 12, 2006 2:51 PM
Subject: RE: [mapguide-users] New configuration problems
Eric,
MapGuide Open Source is a brand new platform and this is a 1.0.0
release. Undoubtedly there are some bugs. However if you interact with
this list and log your bugs as defects using the Project Tracker tool,
we will get them fixed. As a community we are committed to making this
the best platform for creating web mapping applications. Only by working
with the community of users and application developers can we make this
happen.
Bob
  _____
Sent: Sunday, March 12, 2006 2:19 PM
Subject: Re: [mapguide-users] New configuration problems
Bill,
Thank you - that's pretty much what I did, and I'm now able to connect.
Now, it's just a matter of getting things to work!  Ha...
I've played a bit with the Getting Started guide, things seem a bit
"buggy" :) - I'm a bit scared to even think of loading my parcel shape
file just based on issues with the small files supplied - I think mine
might send it to the grave.
However, if it can do what I hope it can - it'll be a great tool.
Any insight is always greatly appreciated.
Thanks,
-- Eric
	----- Original Message -----
	From: Bill Dhimitri <mailto:bill.dhimitri at autodesk.com>
	Sent: Sunday, March 12, 2006 1:07 PM
	Hi Eric,
	Here are some more detailed instructions.  These might help you
identify where it's going wrong.  During steps 2-7 you should not see
the word "Mapserver appear as part of a download or install.
	1.	Use the Windows "Add or Remove Programs" dialog to
remove the currently installed MapGuide Studio (or MapServer Studio).
	2.	Go to this URL:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6153839
	3.	Scroll to the bottom of the page.  You should see a
picture of a Garmin device, and a paragraph with the heading "The
MapGuide Open"
	4.	Just above that, there is link that reads:
StudioSetup.exe (exe - 125407 Kb).  Right click on it and download/save
it to your file system.
	5.	In the Windows File Explorer, right-click on the
StudioSetup.exe file that you downloaded in step 4 and select
Properties.  The "Size:" should read: 126 MB (132,695,040 bytes)
	6.	Now run the StudioSetup.exe that you downloaded in step
4.
	7.	Confirm that the install was successful by opening the
Windows "Add or Remove Programs" dialog.  There should be an entry for
"Autodesk MapGuide (r) Studio Preview.  Click on it, and the "Click here
for support information" link will appear.  Click on that link and you
will see a text box indicating the version number.  It should read
1.0.0.16407.
	Let me know how it goes,
	Bill
  _____
	Sent: Sunday, March 12, 2006 12:24 PM
	Bill,
	Thanks - that's very strange.  Somehow I downloaded Mapserver
studio instead of Mapguide studio.  Perhaps I'm confused - I'm under the
impression that Mapguide Open Source server is really Mapserver.  At any
rate, I was somehow able to download Mapserver Studio (which has the
exact same size footprint and file name as Mapguide Studio).
	Please advise,
	-- Eric
		To: users at mapguide.osgeo.org ; ericbrown at netxn.xom
		Sent: Sunday, March 12, 2006 5:40 AM
		Hi Eric,
		The "version is incompatible" message probably means
that you have an old Studio.  A new one got posted last week to
www.autodesk.com/mapguidestudio with a version number of 1.0.0.16407
(you can use the Help About dialog to confirm the version). If you
download and install the new one, that should fix your problem
		Bill
  _____
		Sent: Sunday, March 12, 2006 8:35 AM
		To: users at mapguide.osgeo.org; ericbrown at netxn.xom
		Hi Eric,
		The mgp file itself is just a zip file containing all
the map resources. Sometimes Internet Explorer changes the extensions of
files it recognizes, so it likely renamed it to .zip when it downloaded
it. Just rename it to .mgp.
		As far as the Studio problem, let's wait for someone
else (who knows better) to answer that. But I am puzzled that you say
MapServer Studio... That's what the 0.9 version was called, the current
one should say MapGuide Studio when it starts up.
		Traian
			-----Original Message-----
			Sent: Sun 3/12/2006 3:14 AM
			Cc:
			Subject: [mapguide-users] New configuration
problems
			All...
			Just downloaded MapGuide & Mapserver Studio.
			While the Admin appears to function fairly
properly - I can't connect from studio, receiving the following message:
"The Studio version is incompatible with the site version."
			Since I downloaded both files today my
assumption would be that all would be synched properly.
			Additionally, though I believe these may be
related based on other posts.. the sheboygan.mgp download file isn't a
.mgp but rather a .zip file doesn't include a  the sheboygan.mgp file.
And I've tried just putting the .zip file in the C:\Program
Files\MapGuideOpenSource\Server\Packages folder to no avail, the admin
doesn't see a package.
			So.. I'm at somewhat of an impasse because I
can't get the demo apps to run because of no data, and I can't play with
the development tool due to a version conflict.
			Any assistance would be greatly appreciated.
			-- Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060312/805a7aee/attachment.html
More information about the Mapguide-users mailing list
