[mapguide-users] New configuration problems
Andy Morsell amorsell at spatialgis.com
Mon Mar 13 01:48:29 EST 2006
This issue was discussed in the older mse-users archive which has not been
transferred to the new osgeo users archive.  Hopefully it will be some day.
You can still access the older archives at:
http://lists.mapserverfoundation.org/pipermail/mse-users/.
For publishing your maps via embedding in an HTML file and establishing a
session based on a user programmatically, see the example applications which
do exactly this.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
[mailto:triplederby100-propos at yahoo.com]
Sent: Sunday, March 12, 2006 10:24 PM
Subject: Re: [mapguide-users] New configuration problems
This problem/behavior with large file was with earlier release too. And it
is not yet fixed, I think, because it happens with large files with 1.0 too.
A workaround was suggested, you may want to search the archive.
Kaarigar
----- Original Message ----
Sent: Sunday, March 12, 2006 10:06:11 PM
Bob,
I'm not sure where to pose this question - but I'm attempting to load a
145mb shape file (my parcel layer) - and it hangs and hangs and hangs and
hangs - then - eventually returns back error free, but the layer isn't
there.  I've attempted the load several times all with the same results.
Also - although I haven't fought very much with this issue yet (and it's
fairly insignificant if I can't get my parcel layer to load) - how do I make
the map published in such a way that it doesn't require challenge/response.
I know this is probably some strange security issue within IIS, but the
permissions appear correct.
 Any help would be greatly appreciated.
-- Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060312/cec35dc1/attachment.html
More information about the Mapguide-users mailing list
