SPAM-LOW: RE: [mapguide-users] Lat Long Display Issue/Bug
Andy Morsell amorsell at spatialgis.com
Wed Mar 15 14:12:23 EST 2006
I am seeing the same thing as you in the DWF viewer if I change my
coordinate display to lat lon.  The lat and lon are reversed.
Sorry, I got confused since I mostly use the AJAX viewer.  In the AJAX
viewer, there isn't an option to change the coordinate display from the MCS
to LL (a different bug?) so I went down this tangent of redefining a map in
LL, creating a new web layout, etc. when I didn't need to.
Andy
-----Original Message-----
Sent: Wednesday, March 15, 2006 10:55 AM
Subject: SPAM-LOW: RE: [mapguide-users] Lat Long Display Issue/Bug
Here is the capture of the Coordinate Display:
Kori Maleski  BSc.
Senior Technical Consultant
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1 TEL
403.770.1917
FAX
877.691.9149
 TOL
877.691.9171
www.pat.ca
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: March 15, 2006 11:28 AM
Subject: RE: [mapguide-users] Lat Long Display Issue/Bug
I have a map defined in Washington State Plane NAD83 North (ft) and both the
DWF viewer and the AJAX viewer display X and Y correctly.  The only bug I
see is that the DWF viewer displays (degrees) in the statusbar when it
should say (feet).  I think that is already a noted defect, however.
I just tried changing the definition to NAD27 and same thing, X is X and Y
is Y.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, March 15, 2006 10:05 AM
Subject: [mapguide-users] Lat Long Display Issue/Bug
Hi All,
I have a map that I am displaying in Washington State Plane NAD27 North (ft)
projection and the DWF viewer is switching the Lat for Lon in the coordinate
display.
Anyone else see this?  Does this mean we have to switch them for the
ZoomToView function as well?
Cheers,
Kori Maleski  BSc.
403.770.1917
FAX
877.691.9149
 TOL
877.691.9171
www.pat.ca
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
