Dynamic Maps
Steven J Reed sjreed at edcomputing.com
Fri Mar 17 20:36:01 EST 2006
My MapGuide 6.5 application dynamically creates layers (SDFs) from external
databases, adding them to the display and to the MWX file which is turned
back into the MWF for later use.  Symbols are also added to the MWX as
needed.
Is there a capability within the New MapGuide to dynamically create layers?
Everything I read talks about pre-defined 'Resources', so maybe there's a
means (through an API?) to dynamically add resources.
I'd appreciate anyone pointing me in the right direction to make this
happen!
Thanks.Steve
_____________________________
Steven J. Reed
El Dorado Computing
P. O. Box 5745
Stateline, NV   89449-5745
(775) 589-6850   (916) 226-9065 Fax: (503) 218-7622
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060317/89a30c8c/attachment.html
More information about the Mapguide-users mailing list
