[mapguide-users] SDF load problems
Andy Morsell amorsell at spatialgis.com
Wed Mar 22 17:37:12 EST 2006
This is where using a managed data structure is a detriment, in my opinion.
Many of us will want to update our data through external processes and there
is no easy way to just copy files into the repository or point to an
existing network location.  I think this is going to become a much bigger
problem as people put these systems into production and realize that they
have to "load" their data into repositories.  It's also going to be a large
problem for keeping data up to date with ongoing system maintenance.
Scheduled process are going to be a necessity to ensure that the data in the
repository is in synch with the source data.  And, in the case of large
source datasets, the entire dataset will have to be reloaded as there is no
incremental update method.
I believe (but have not yet done this) that the Studio API is going to have
to be used to load these resources, not the server API.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
Sent: Wednesday, March 22, 2006 2:17 PM
Subject: RE: [mapguide-users] SDF load problems
Ahhh. I see, I misunderstood the use of "Packages" and didn't think too look
there.   Thank you. It is working fine now.
I have noticed that imported SDFs are processed (into SDF v3, I believe). Is
it currently possible to import SDF data sources into the repository without
using Studio at all, just using the server API? Is it possible to create
your own Packages using the server API?  I would be interested in doing this
for our migration tools.
Joel Carranza
Gatekeeper Systems
626-449-3070 x114
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, March 22, 2006 1:42 PM
It looks like it's too big.  You'll probably have to "Package" the data and
upload it to the server manually, then bring it in via the site Admin web
app.
Jason
  _____
Sent: Wednesday, March 22, 2006 13:39
Subject: [mapguide-users] SDF load problems
I am trying to load a 225 MB SDF file using MapGuide studio. I have tried
any number of different options and they all seem to fail. The process
crunches for a while, and then says "Communicating with server" and the
progress bars fills to 100% .  Eventually, an error dialog is popped that
says "Unable to complete request to site. Connection lost".
The apache logs showed the following. None of the other logs reported
anything of interest that I could see.
[Wed Mar 22 13:33:54 2006] [warn] FastCGI: (dynamic) server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
restarted (pid 5284)
[Wed Mar 22 13:34:00 2006] [warn] FastCGI: scheduled the restart of the last
process: reached dynamicMaxClassProcs (10)
[Wed Mar 22 13:34:00 2006] [warn] FastCGI: (dynamic) server "C:/Program
restarted (pid 6008)
[Wed Mar 22 13:34:21 2006] [warn] FastCGI: (dynamic) server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe" (pid
5540) terminated with exit with status '0'
[Wed Mar 22 13:34:38 2006] [warn] FastCGI: (dynamic) server "C:/Program
6008) termination signaled
[Wed Mar 22 13:34:39 2006] [warn] FastCGI: (dynamic) server "C:/Program
6008) terminated with exit with status '0'
Anyone have any ideas about what is going on?
Joel Carranza
Gatekeeper Systems
626-449-3070 x114
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060322/a83b6ea5/attachment.html
More information about the Mapguide-users mailing list
