[mapguide-users] aclocal warnings Fedora 4 build
Walt Welton-Lair walt.welton-lair at autodesk.com
Thu Mar 23 00:28:12 EST 2006
Your output shows no errors - only warnings.  IIRC we had similar warnings on our Fedora machine.  I think you can safely ignore these.
Walt
	-----Original Message-----
	Sent: Wed 3/22/2006 11:49 PM
	Cc:
	Subject: [mapguide-users] aclocal warnings Fedora 4 build
	Apparently there is a conflict with my version of automake (1.9).   I
	get the following error with the aclocal command:
	[root at jagdpup mapguide-1.0.0]# aclocal
	acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
	  run info '(automake)Extending aclocal'
	  or see http://sources.redhat.com/automake/automake.html#Extending-aclocal
	acinclude.m4:12: warning: underquoted definition of MAP_SUBST
	acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
	acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
	acinclude.m4:67: warning: underquoted definition of MAP_GENERATE_MAKEFILES
	acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
	acinclude.m4:83: warning: underquoted definition of MAP_DEFINE_TYPE_RLIM_T
	acinclude.m4:108: warning: underquoted definition of MAP_SUBST_EXPANDED_ARG
	acinclude.m4:115: warning: underquoted definition of MAP_EXPORT_ARGUMENTS
	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060323/689e9c7c/attachment.bin
More information about the Mapguide-users mailing list
