[mapguide-users] login
Traian Stanev traian.stanev at autodesk.com
Mon Mar 27 10:09:38 EST 2006
Is there an mgserver.exe under C:\Program
Files\MapGuideOpenSource\Server\Bin?
If not, then you didn't install the mapguide server and you need to do
so.
If there is, then open a command prompt, go to that directory and try
running
mgserver /interactive
This will either manually start the server, or report any errors that
prevent it from starting.
Traian
-----Original Message-----
From: volunteer at spatiallink.org [mailto:volunteer at spatiallink.org]
Sent: Monday, March 27, 2006 9:59 AM
Subject: RE: [mapguide-users] login
...no, I did check under Services- there is no MapGuide Server service.
Harsh
> -------- Original Message --------
> From: "Traian Stanev" <traian.stanev at autodesk.com>
> Date: Mon, March 27, 2006 9:50 am
> To: <users at mapguide.osgeo.org>
> Is the MapGuide Server service started? Please check the attached
> screenshot to see what I mean.
> Traian
> Sent: Monday, March 27, 2006 9:44 AM
> Traian,
> There is no mgserver.exe under C:- I am using WebServer Extensions. I
> have a MapAgent.exe under ../www/mapagent/.
> Harsh
> > Date: Mon, March 27, 2006 9:21 am
> > Cc: "Robert Bray" <robert.bray at autodesk.com>, "Dave Wilson"
> > <dave.wilson at autodesk.com>
> > Hi Harsh,
> > The MapGuide server is a service running in addition to your web
> server.
> > In the task manager, look for mgserver.exe. If that is not running
> you
> > will need to start it manually.
> > Traian
> > Sent: Monday, March 27, 2006 9:17 AM
> > Cc: Robert Bray; Dave Wilson
> > Rob,
> > ApacheMonitor.exe shows up as running under Task Manager [WIN2003].
> > I restart ApacheMapGuide and try to login to login.php, but get the
> > following error message:
> > "Authentication Failed. Please enter a valid username and password."
> > Harsh
> > > From: "Robert Bray" <robert.bray at autodesk.com>
> > > Date: Sun, March 26, 2006 2:58 am
> > > Cc: "Dave Wilson" <dave.wilson at autodesk.com>
> > >  Harsh,   Is the MapGuide Server Service installed and running?
> > Sometimes it does not auto-start after install.   Bob
> > >  Sent: Saturday, March 25, 2006 5:38 PM
> > >  Cc: Dave Wilson
> > >  Dave/Others-
> > >  I am trying to install MapGuide OpenSource Web Server Extensions.
> > >  I tried it on Windows XP Professional on both ports- #8008 with
> MS4W
> > and #80 withOUT MS4W. I followed the instructions in
> https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf
> > for PHP. Then I tried logging-in to ../mapguide/mapadmin/login.php
> using
> > 'Administrator' and 'admin' [case-sensitive] with both, Firefox and
> > Internet Explorer. This leads to an 'incorrect login' error. Apache
> > MapGuide service is running during these attempts.
> > >  I am now trying the same on Windows 2003 Professional Server.
> > >  Thanks, Harsh   -------- Original Message --------
> > >  From: "Dave Wilson" <dave.wilson at autodesk.com>
> > >  Date: Fri, March 24, 2006 7:02 pm
> > >  Could you kindly provide more details please?
> > >  For example are you logging into the Webadmin php page? For
> example
> > >  http://localhost:8008/mapguide/mapadmin/login.php for Apache.
> > >  Are you getting an error message if so what is it?.
> > >  Regards,
> > >  Dave
> > >  Sent: Friday, March 24, 2006 4:47 PM
> > >  Subject: [mapguide-users] login
> > >  username: Administrator
> > >  password: admin
> > >  ...do not work even when Apache MapGuide is running [WIN2003].
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
