[mapguide-users] PHP to ASP
Robert Bray robert.bray at autodesk.com
Mon Mar 27 11:46:49 EST 2006
Yes, that will work. If you are running Windows Server 2003 with IIS 6
there are a couple of extra configuration steps to look out for. They
are documented in the Install and Configure document and there has been
some discussion on this list as well.
Bob
  _____
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Monday, March 27, 2006 8:25 AM
Subject: RE: [mapguide-users] PHP to ASP
Robert, thanks for responding.  I have decided to go ahead with .NET.
Since I have already installed PHP, how is .NET installed?  Do I just
re-run the webextensions and choose .NET this time and then bot PHP and
.NET will co-exisit?
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
<http://www.maintenanceconnection.com/>
-----Original Message-----
From: Robert Bray [mailto:robert.bray at autodesk.com]
Sent: Friday, March 24, 2006 2:01 PM
Randy,
Which PHP pages are you referring to? Everything but the Admin tool is
available in PHP, ASP.NET, and Java. PHP and ASP.NET can co-exist, so
what's the issue?
Bob
  _____
Sent: Friday, March 24, 2006 1:26 PM
Subject: [mapguide-users] PHP to ASP
I have a need to be in ASP.  Would it be possible to re-write the PHP
pages in ASP?  Is there stuff being done in the PHP that only PHP can
do? Or would it be too much work?
Just looking at some of the pages it looks possible but I would rather
ask first....
Best Regards,
Randy Glen Johnson
Programmer Analyst
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060327/9aecb80d/attachment.html
More information about the Mapguide-users mailing list
