[mapguide-users] make errors building web exstentions
Bas van den Dikkenberg bas at giskit.nl
Wed Mar 29 14:59:25 EST 2006
Now i have install gcc4 also but how do i tellet hat he must gcc4 and
not the other gcc
Met vriendelijk groet,
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Prive Tel:          +3130-6372769
Mob:                +316-52384841
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: dinsdag 28 maart 2006 21:28
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] make errors building web exstentions
Also make sure it is 4.0.2 and not 4.0.0. It is possible that it will
build fine but hang on startup with 4.0.0 due to some problems with
initialization of the Xerces library. It will be fine with 4.0.2.
From: Bas van den Dikkenberg [mailto:bas at giskit.nl]
Sent: Tuesday, March 28, 2006 1:38 PM
Subject: RE: [mapguide-users] make errors building web exstentions
Gcc 4 is also installed but fort hat i need to use the gcc4 comamnd and
not gcc how do tell de build script to gcc4
Van: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Verzonden: donderdag 23 maart 2006 16:58
It looks like errors due to templates.  You're not the first one
encountering this:
http://gcc.gnu.org/ml/gcc-help/2004-12/msg00077.html
http://gcc.gnu.org/ml/gcc-help/2004-11/msg00093.html
At this point I can only recommend upgrading your gcc / g++ to version
4.0.2.
Walt
Sent: Wednesday, March 22, 2006 4:23 PM
Linux redhat2 2.6.9-34.EL #1 Fri Feb 24 16:44:51 EST 2006 i686 i686 i386
GNU/Linux
gcc (GCC) 3.4.5 20051201 (Red Hat 3.4.5-2)
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Mob:                +316-52384841
Verzonden: woensdag 22 maart 2006 16:24
What kernel / flavor of Linux are you building on?
What version of g++ are you using?
It's always good to include this info when reporting build errors...
Sent: Wednesday, March 22, 2006 2:01 AM
Jpeg problem solved the devel pakage was not installed but now i'm
getting te following error output:
mv -f CoordSysOutOfMemoryException.o
.libs/CoordSysOutOfMemoryException.lo
g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
-DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
-DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
-DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
-DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
-DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1
-DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
-DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1
-DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1
-DHAVE_SHUTDOWN=1 -I. -I. -I../../Oem/gdal-1.3.0/ogr
-I../../Oem/gdal-1.3.0/port -I../../Oem/proj-4.4.9/src -g -D_DEBUG -c
CoordSysOutOfMemoryException.cpp -MT CoordSysOutOfMemoryException.lo -MD
-MP -MF .deps/CoordSysOutOfMemoryException.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysOutOfMemoryException.lo
source='CoordSysTransform.cpp' object='CoordSysTransform.lo' libtool=yes
depfile='.deps/CoordSysTransform.Plo'
tmpdepfile='.deps/CoordSysTransform.TPlo' \
depmode=gcc3 /bin/sh ../../depcomp \
/bin/sh ../../libtool --mode=compile g++ -DPACKAGE_NAME=\"mapguide\"
-DPACKAGE_TARNAME=\"mapguide\" -DPACKAGE_VERSION=\"1.0.0\"
-DPACKAGE_STRING=\"mapguide\ 1.0.0\"
-o CoordSysTransform.lo `test -f 'CoordSysTransform.cpp' || echo
'./'`CoordSysTransform.cpp
rm -f .libs/CoordSysTransform.lo
CoordSysTransform.cpp -MT CoordSysTransform.lo -MD -MP -MF
.deps/CoordSysTransform.TPlo  -fPIC -DPIC
In file included from ../../Oem/gdal-1.3.0/port/cpl_port.h:160,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_core.h:117,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_srs_api.h:193,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_spatialref.h:99,
                 from CoordSysIncludes.h:21,
                 from CoordSysTransform.cpp:19:
../../Oem/gdal-1.3.0/port/cpl_config.h:105:1: warning:
"PACKAGE_BUGREPORT" redefined
<command line>:6:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:108:1: warning: "PACKAGE_NAME"
redefined
<command line>:2:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:111:1: warning: "PACKAGE_STRING"
redefined
<command line>:5:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:114:1: warning: "PACKAGE_TARNAME"
redefined
<command line>:3:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:117:1: warning: "PACKAGE_VERSION"
redefined
<command line>:4:1: warning: this is the location of the previous
definition
mv -f CoordSysTransform.o .libs/CoordSysTransform.lo
.deps/CoordSysTransform.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransform.lo CoordSysTransform.lo
source='CoordSysTransformation.cpp' object='CoordSysTransformation.lo'
libtool=yes \
depfile='.deps/CoordSysTransformation.Plo'
tmpdepfile='.deps/CoordSysTransformation.TPlo' \
-o CoordSysTransformation.lo `test -f 'CoordSysTransformation.cpp' ||
echo './'`CoordSysTransformation.cpp
rm -f .libs/CoordSysTransformation.lo
CoordSysTransformation.cpp -MT CoordSysTransformation.lo -MD -MP -MF
.deps/CoordSysTransformation.TPlo  -fPIC -DPIC
                 from CoordSysTransformation.cpp:19:
definition
redefined
definition
redefined
definition
redefined
definition
redefined
definition
mv -f CoordSysTransformation.o .libs/CoordSysTransformation.lo
.deps/CoordSysTransformation.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransformation.lo CoordSysTransformation.lo
source='CoordSysTransformFailedException.cpp'
object='CoordSysTransformFailedException.lo' libtool=yes \
depfile='.deps/CoordSysTransformFailedException.Plo'
tmpdepfile='.deps/CoordSysTransformFailedException.TPlo' \
-o CoordSysTransformFailedException.lo `test -f
'CoordSysTransformFailedException.cpp' || echo
'./'`CoordSysTransformFailedException.cpp
rm -f .libs/CoordSysTransformFailedException.lo
CoordSysTransformFailedException.cpp -MT
CoordSysTransformFailedException.lo -MD -MP -MF
.deps/CoordSysTransformFailedException.TPlo  -fPIC -DPIC
                 from CoordSysTransformFailedException.cpp:19:
definition
redefined
definition
redefined
definition
redefined
definition
redefined
definition
mv -f CoordSysTransformFailedException.o
.deps/CoordSysTransformFailedException.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransformFailedException.lo
/bin/sh ../../libtool --mode=link g++  -g -D_DEBUG   -o
libMgCoordinateSystem.la -rpath /usr/local/mapguideopensource/lib
-version-info 7:0:0 -L../../Oem/gdal-1.3.0 -L../../Oem/proj-4.4.9/src
CoordSys.lo CoordSysCatalog.lo CoordSysCategory.lo
CoordSysCategoryCollection.lo CoordSysComputationFailedException.lo
CoordSysConversionFailedException.lo CoordSysEnvelope.lo
CoordSysException.lo CoordSysFactory.lo CoordSysInformation.lo
CoordSysInitializationFailedException.lo
CoordSysInvalidArgumentException.lo
CoordSysInvalidCoordinateSystemException.lo
CoordSysInvalidCoordinateSystemTypeException.lo
CoordSysInvalidCoordinateSystemUnitsException.lo CoordSysMeasure.lo
CoordSysMeasureFailedException.lo CoordSysNullArgumentException.lo
CoordSysNullReferenceException.lo CoordSysOutOfMemoryException.lo
CoordSysTransform.lo CoordSysTransformation.lo
CoordSysTransformFailedException.lo -lgdal -lproj
rm -fr .libs/libMgCoordinateSystem.la .libs/libMgCoordinateSystem.*
gcc -shared  CoordSys.lo CoordSysCatalog.lo CoordSysCategory.lo
CoordSysTransformFailedException.lo  -Wl,--rpath
-Wl,/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0/.libs
-Wl,--rpath
-Wl,/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src/.libs
-Wl,--rpath -Wl,/usr/local/mapguideopensource/lib  -L/usr/lib/mysql
-L/usr/lib -L/usr/local/lib
-L/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0
-L/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src
/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0/.libs/libgdal.so
/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src/.libs/libproj
.so    -Wl,-soname -Wl,libMgCoordinateSystem.so.7 -o
.libs/libMgCoordinateSystem.so.7.0.0
(cd .libs && rm -f libMgCoordinateSystem.so.7 && ln -s
libMgCoordinateSystem.so.7.0.0 libMgCoordinateSystem.so.7)
(cd .libs && rm -f libMgCoordinateSystem.so && ln -s
libMgCoordinateSystem.so.7.0.0 libMgCoordinateSystem.so)
ar cru .libs/libMgCoordinateSystem.a  CoordSys.o CoordSysCatalog.o
CoordSysCategory.o CoordSysCategoryCollection.o
CoordSysComputationFailedException.o CoordSysConversionFailedException.o
CoordSysEnvelope.o CoordSysException.o CoordSysFactory.o
CoordSysInformation.o CoordSysInitializationFailedException.o
CoordSysInvalidArgumentException.o
CoordSysInvalidCoordinateSystemException.o
CoordSysInvalidCoordinateSystemTypeException.o
CoordSysInvalidCoordinateSystemUnitsException.o CoordSysMeasure.o
CoordSysMeasureFailedException.o CoordSysNullArgumentException.o
CoordSysNullReferenceException.o CoordSysOutOfMemoryException.o
CoordSysTransform.o CoordSysTransformation.o
ranlib .libs/libMgCoordinateSystem.a
creating libMgCoordinateSystem.la
(cd .libs && rm -f libMgCoordinateSystem.la && ln -s
../libMgCoordinateSystem.la libMgCoordinateSystem.la)
make[2]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Common/CoordinateSystem'
Making all in MdfModel
make[2]: Entering directory
`/home/download/mapserver/mapguide-1.0.0/Common/MdfModel'
make[2]: Nothing to be done for `all'.
Making all in MdfParser
`/home/download/mapserver/mapguide-1.0.0/Common/MdfParser'
Making all in Security
`/home/download/mapserver/mapguide-1.0.0/Common/Security'
Making all in Service
`/home/download/mapserver/mapguide-1.0.0/Common/Service'
source='Controller/ServiceControllerBuild.cpp'
object='ServiceControllerBuild.lo' libtool=yes \
depfile='.deps/ServiceControllerBuild.Plo'
tmpdepfile='.deps/ServiceControllerBuild.TPlo' \
-DHAVE_SHUTDOWN=1  -I. -I. -IController -ICoordinateSystem -IData
-IException -IGeometry -IMapLayer -INet -IServices -ISystem -IUtil
-I../Security -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
-I../../Oem/geos-2.2.0/source/headers
-I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
-I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
-I../../Common/CoordinateSystem    -g -D_DEBUG -c -o
ServiceControllerBuild.lo `test -f
'Controller/ServiceControllerBuild.cpp' || echo
'./'`Controller/ServiceControllerBuild.cpp
rm -f .libs/ServiceControllerBuild.lo
Controller/ServiceControllerBuild.cpp -MT ServiceControllerBuild.lo -MD
-MP -MF .deps/ServiceControllerBuild.TPlo  -fPIC -DPIC
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
                 from ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
                 from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
                 from ./AceCommon.h:56,
                 from Controller/Controller.cpp:18,
                 from Controller/ServiceControllerBuild.cpp:18:
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
COMPARE_KEYS, ACE_LOCK>::close_i()':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
expected class-name before '(' token
COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID, INT_ID>*)':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
                 from
../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
                 from ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member function
`void ACE_Unbounded_Queue<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
`ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error: expected
`int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
                 from ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
                 from ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
                 from
../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
`void ACE_Unbounded_Set<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
`ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error: expected
`int ACE_Unbounded_Set<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
                 from
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
`void ACE_Unbounded_Stack<T>::delete_all_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
`ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function `int
ACE_Unbounded_Stack<T>::pop(T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
ACE_Unbounded_Stack<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
ACE_Ordered_MultiSet<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error: expected
`void ACE_Ordered_MultiSet<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error: expected
make[2]: *** [ServiceControllerBuild.lo] Error 1
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Common'
make: *** [all-recursive] Error 1
Verzonden: dinsdag 21 maart 2006 23:08
The errors appear to be jpeg-related.  Do you have the jpeg package
installed on your machine?  It's required...
Sent: Tuesday, March 21, 2006 5:04 PM
Subject: [mapguide-users] make errors building web exstentions
If have run the following command  a cording to manual
./build_oem.sh
Then ./configure --enable-server=no still no errors
When I run make I get following error wat am I doing wrong?
/usr/bin/install -c -m 644 'macro_draw.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_draw.h'
 /usr/bin/install -c -m 644 'macro_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_scale.h'
 /usr/bin/install -c -m 644 'macro_index.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_index.h'
 /usr/bin/install -c -m 644 'marksize.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksize.h'
 /usr/bin/install -c -m 644 'marksymb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksymb.h'
 /usr/bin/install -c -m 644 'matrix.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/matrix.h'
 /usr/bin/install -c -m 644 'merge_control.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/merge_control.h'
 /usr/bin/install -c -m 644 'named_view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view.h'
 /usr/bin/install -c -m 644 'named_view_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view_list.h'
 /usr/bin/install -c -m 644 'object.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object.h'
 /usr/bin/install -c -m 644 'object_node.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node.h'
 /usr/bin/install -c -m 644 'object_node_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node_list.h'
 /usr/bin/install -c -m 644 'object_stream.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_stream.h'
 /usr/bin/install -c -m 644 'opcode.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode.h'
 /usr/bin/install -c -m 644 'opcode_defs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode_defs.h'
 /usr/bin/install -c -m 644 'origin.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/origin.h'
 /usr/bin/install -c -m 644 'overpost.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/overpost.h'
 /usr/bin/install -c -m 644 'palette.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/palette.h'
 /usr/bin/install -c -m 644 'pattern_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pattern_scale.h'
 /usr/bin/install -c -m 644 'pch.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pch.h'
 /usr/bin/install -c -m 644 'penpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat.h'
 /usr/bin/install -c -m 644 'penpat_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat_options.h'
 /usr/bin/install -c -m 644 'plot_optimized.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plot_optimized.h'
 /usr/bin/install -c -m 644 'plotinfo.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plotinfo.h'
 /usr/bin/install -c -m 644 'pnggroup4image.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pnggroup4image.h'
 /usr/bin/install -c -m 644 'point.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/point.h'
 /usr/bin/install -c -m 644 'pointset.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pointset.h'
 /usr/bin/install -c -m 644 'polygon.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polygon.h'
 /usr/bin/install -c -m 644 'polyline.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polyline.h'
 /usr/bin/install -c -m 644 'polymark.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polymark.h'
 /usr/bin/install -c -m 644 'polytri.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polytri.h'
 /usr/bin/install -c -m 644 'preload.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/preload.h'
 /usr/bin/install -c -m 644 'projection.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/projection.h'
 /usr/bin/install -c -m 644 'rendition.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendition.h'
 /usr/bin/install -c -m 644 'rendopts.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendopts.h'
 /usr/bin/install -c -m 644 'resource.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/resource.h'
 /usr/bin/install -c -m 644 'rgb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rgb.h'
 /usr/bin/install -c -m 644 'signdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/signdata.h'
 /usr/bin/install -c -m 644 'text.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text.h'
 /usr/bin/install -c -m 644 'text_background.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_background.h'
 /usr/bin/install -c -m 644 'text_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_options.h'
 /usr/bin/install -c -m 644 'text_halign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_halign.h'
 /usr/bin/install -c -m 644 'text_valign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_valign.h'
 /usr/bin/install -c -m 644 'timestamp.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/timestamp.h'
 /usr/bin/install -c -m 644 'transform.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/transform.h'
 /usr/bin/install -c -m 644 'trusted_font_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/trusted_font_list.h'
 /usr/bin/install -c -m 644 'typedefs_defines.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/typedefs_defines.h'
 /usr/bin/install -c -m 644 'units.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/units.h'
 /usr/bin/install -c -m 644 'unknown.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/unknown.h'
 /usr/bin/install -c -m 644 'url.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url.h'
 /usr/bin/install -c -m 644 'url_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url_list.h'
 /usr/bin/install -c -m 644 'userdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/userdata.h'
 /usr/bin/install -c -m 644 'usrfillpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrfillpat.h'
 /usr/bin/install -c -m 644 'usrhatchpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrhatchpat.h'
 /usr/bin/install -c -m 644 'view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/view.h'
 /usr/bin/install -c -m 644 'viewport.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport.h'
 /usr/bin/install -c -m 644 'viewport_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport_options.h'
 /usr/bin/install -c -m 644 'visible.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/visible.h'
 /usr/bin/install -c -m 644 'whip_toolkit.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whip_toolkit.h'
 /usr/bin/install -c -m 644 'whipcore.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whipcore.h'
 /usr/bin/install -c -m 644 'whiperrs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whiperrs.h'
 /usr/bin/install -c -m 644 'wtstring.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wtstring.h'
 /usr/bin/install -c -m 644 'wversion.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wversion.h'
 /usr/bin/install -c -m 644 'wendian.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wendian.h'
make[8]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src
/dwf/whiptk'
make[7]: Leaving directory
/dwf/whiptk'
Making install in w3dtk
make[7]: Entering directory
/dwf/w3dtk'
Making install in jpeg
make[8]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg"
 /usr/bin/install -c -m 644 'jchuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jchuff.h'
 /usr/bin/install -c -m 644 'jconfig.cfg'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.cfg'
 /usr/bin/install -c -m 644 'jconfig.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.h'
 /usr/bin/install -c -m 644 'jconfig.hpux'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.hpux'
 /usr/bin/install -c -m 644 'jconfig.irix'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.irix'
 /usr/bin/install -c -m 644 'jconfig.solaris'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.solaris'
 /usr/bin/install -c -m 644 'jconfig.vc'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vc'
 /usr/bin/install -c -m 644 'jconfig.vms'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vms'
 /usr/bin/install -c -m 644 'jdct.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdct.h'
 /usr/bin/install -c -m 644 'jdhuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdhuff.h'
 /usr/bin/install -c -m 644 'jerror.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jerror.h'
 /usr/bin/install -c -m 644 'jinclude.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jinclude.h'
 /usr/bin/install -c -m 644 'jmemsys.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmemsys.h'
 /usr/bin/install -c -m 644 'jmorecfg.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmorecfg.h'
 /usr/bin/install -c -m 644 'jpegint.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpegint.h'
 /usr/bin/install -c -m 644 'jpeglib.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpeglib.h'
 /usr/bin/install -c -m 644 'jversion.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jversion.h'
make[9]: Leaving directory
/dwf/w3dtk/jpeg'
/dwf/w3dtk/jpeg'
Making install in utility
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/utility" ||
mkdir -p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/utility"
 /usr/bin/install -c -m 644 'varray.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/varray.h'
 /usr/bin/install -c -m 644 'vconf.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vconf.h'
 /usr/bin/install -c -m 644 'vhash.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vhash.h'
 /usr/bin/install -c -m 644 'vheap.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vheap.h'
 /usr/bin/install -c -m 644 'vlist.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlist.h'
 /usr/bin/install -c -m 644 'vlogfile.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlogfile.h'
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
Making install in hoops
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops"
 /usr/bin/install -c -m 644 'hoops_tools.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/hoops_tools.h'
 /usr/bin/install -c -m 644 'lod.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/lod.h'
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
/dwf/w3dtk'
if /bin/sh ../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H
-I../..   -DBSTREAM_DISABLE_REPULSE_COMPRESSION  -g0 -O2 -pipe -pedantic
-Wall -Wno-long-long  -Wnon-virtual-dtor -Wsign-promo -Wsign-compare
-Wundef -Wstrict-prototypes -fforce-addr -fomit-frame-pointer
-finline-functions -ffast-math -fno-strict-aliasing -MT
BOpcodeHandler.lo -MD -MP -MF ".deps/BOpcodeHandler.Tpo" -c -o
BOpcodeHandler.lo BOpcodeHandler.cpp; \
then mv -f ".deps/BOpcodeHandler.Tpo" ".deps/BOpcodeHandler.Plo"; else
rm -f ".deps/BOpcodeHandler.Tpo"; exit 1; fi
 g++ -DHAVE_CONFIG_H -I../.. -DBSTREAM_DISABLE_REPULSE_COMPRESSION -g0
-O2 -pipe -pedantic -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
-Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
-fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing
-MT BOpcodeHandler.lo -MD -MP -MF .deps/BOpcodeHandler.Tpo -c
BOpcodeHandler.cpp  -fPIC -DPIC -o .libs/BOpcodeHandler.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
BOpcodeHandler.cpp:4948: error: field `jerr' has incomplete type
BOpcodeHandler.cpp:4954: error: variable or field `my_jpeg_messages'
declared void
BOpcodeHandler.cpp:4954: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4954: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4962: error: variable or field `my_jpeg_error'
declared void
BOpcodeHandler.cpp:4962: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4962: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4977: error: variable or field `init_destination'
declared void
BOpcodeHandler.cpp:4977: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:4977: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4985: error: `boolean' does not name a type
BOpcodeHandler.cpp:5002: error: variable or field `term_destination'
declared void
BOpcodeHandler.cpp:5002: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5002: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp: In member function `TK_Status
TK_Image::compress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5022: error: aggregate `jpeg_compress_struct cinfo'
has incomplete type and cannot be defined
BOpcodeHandler.cpp:5023: error: aggregate `jpeg_destination_mgr dest'
BOpcodeHandler.cpp:5025: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5025: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5029: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5029: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5031: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5032: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5035: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5035: warning: unused variable
'jpeg_destroy_compress'
BOpcodeHandler.cpp:5044: error: `jpeg_create_compress' was not declared
in this scope
BOpcodeHandler.cpp:5048: error: `empty_output_buffer' was not declared
in this scope
BOpcodeHandler.cpp:5055: error: `JCS_RGB' was not declared in this scope
BOpcodeHandler.cpp:5057: error: `jpeg_set_defaults' was not declared in
this scope
BOpcodeHandler.cpp:5058: error: `FALSE' was not declared in this scope
BOpcodeHandler.cpp:5058: error: `jpeg_set_quality' was not declared in
this scope
BOpcodeHandler.cpp:5067: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5067: error: `jpeg_start_compress' was not declared
in this scope
BOpcodeHandler.cpp:5069: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5070: error: `jpeg_write_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5070: warning: unused variable 'jpeg_write_scanlines'
BOpcodeHandler.cpp:5075: error: `jpeg_finish_compress' was not declared
in this scope
BOpcodeHandler.cpp:5077: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5029: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5044: warning: unused variable 'jpeg_create_compress'
BOpcodeHandler.cpp:5048: warning: unused variable 'empty_output_buffer'
BOpcodeHandler.cpp:5055: warning: unused variable 'JCS_RGB'
BOpcodeHandler.cpp:5057: warning: unused variable 'jpeg_set_defaults'
BOpcodeHandler.cpp:5058: warning: unused variable 'FALSE'
BOpcodeHandler.cpp:5058: warning: unused variable 'jpeg_set_quality'
BOpcodeHandler.cpp:5067: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5067: warning: unused variable 'jpeg_start_compress'
BOpcodeHandler.cpp:5075: warning: unused variable 'jpeg_finish_compress'
BOpcodeHandler.cpp:5077: warning: unused variable
BOpcodeHandler.cpp: At global scope:
BOpcodeHandler.cpp:5171: error: variable or field `init_source' declared
void
BOpcodeHandler.cpp:5171: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5171: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5179: error: `boolean' does not name a type
BOpcodeHandler.cpp:5185: error: variable or field `skip_input_data'
declared void
BOpcodeHandler.cpp:5185: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5185: error: expected primary-expression before
"long"
BOpcodeHandler.cpp:5185: error: initializer expression list treated as
compound expression
BOpcodeHandler.cpp:5185: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5201: error: variable or field `term_source' declared
void
BOpcodeHandler.cpp:5201: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5201: error: expected `,' or `;' before '{' token
TK_Image::decompress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5254: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5255: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5257: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5257: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5260: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5260: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5262: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5263: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5266: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5266: warning: unused variable
'jpeg_destroy_decompress'
BOpcodeHandler.cpp:5270: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5274: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5276: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5283: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5283: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5285: error: `jpeg_start_decompress' was not declared
in this scope
BOpcodeHandler.cpp:5287: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5288: error: `jpeg_read_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5288: warning: unused variable 'jpeg_read_scanlines'
BOpcodeHandler.cpp:5290: error: `jpeg_finish_decompress' was not
BOpcodeHandler.cpp:5292: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5257: warning: unused variable 'JSAMPROW'
BOpcodeHandler.cpp:5260: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5270: warning: unused variable
'jpeg_create_decompress'
BOpcodeHandler.cpp:5274: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5276: warning: unused variable
'jpeg_resync_to_restart'
BOpcodeHandler.cpp:5283: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5283: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5285: warning: unused variable
'jpeg_start_decompress'
BOpcodeHandler.cpp:5290: warning: unused variable
'jpeg_finish_decompress'
BOpcodeHandler.cpp:5292: warning: unused variable
TK_Image::read_jpeg_header()':
BOpcodeHandler.cpp:5357: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5358: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5361: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5361: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5362: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5363: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5366: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5366: warning: unused variable
BOpcodeHandler.cpp:5370: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5373: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5375: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5382: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5382: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5389: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5361: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5370: warning: unused variable
BOpcodeHandler.cpp:5373: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5375: warning: unused variable
BOpcodeHandler.cpp:5382: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5382: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5389: warning: unused variable
make[8]: *** [BOpcodeHandler.lo] Error 1
/dwf/w3dtk'
make[7]: *** [install-recursive] Error 1
/dwf/w3dtk'
make[6]: *** [install-recursive] Error 1
make[6]: Leaving directory
/dwf'
make[5]: *** [install-recursive] Error 1
make[5]: Leaving directory
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop'
make[2]: *** [install-recursive] Error 1
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/download/mapserver/mapguide-1.0.0/Oem'
make: *** [install-recursive] Error 1
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Mob:                +316-52384841
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060329/2a5eabcc/attachment.html
More information about the Mapguide-users mailing list
