[mapguide-users] Installing mapguide
Jason Birch Jason.Birch at nanaimo.ca
Thu May 4 12:43:12 EDT 2006
You might have to specify --enable-shared as an input to the configure
script.
Jason
-----Original Message-----
From: Javier de la Torre [mailto:jatorre at gmail.com]
Sent: Thursday, May 04, 2006 09:36
Subject: Re: [mapguide-users] Installing mapguide
no, there is nothing there...
Am I installing the correct library? In the documentation it says:
The libjpeg.so library is required. It is installed by default with most
Linux distributions. If you do not have it, you can download the source
from the Independent JPEG Group: www.ijg.org.
I downloaded from there:
http://www.ijg.org/files/jpegsrc.v6b.tar.gz
Now I am not sure...
JAvier.
On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> Did it put it under /usr/local/include by any chance?
> Sent: Thursday, May 04, 2006 12:23 PM
> Yes, I was logged as root.
> The file /usr/include/jpeglib.h does not exist.
> I downloaded the jpeg-6b and installed it but does not seems to
> include this file. It copies others to usr/local/bin.
> Thanks.
> > Were you logged in as root when you did make install? Do you have
> > jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > Traian
> > Sent: Thursday, May 04, 2006 12:09 PM
> > Subject: [mapguide-users] Installing mapguide
> > Hi,
> > I am installing mapguide right now, but I am having some problems
> > following the instructions on the PDF file.
> > I am trying to use all the default settings on an Intel with Red Hat
> 9.
> > First I installed Apache, Tomcat and PHP (APT) using the provided
> > package. Everything seems to be fine, the servers are available and
> > everyhting worked fine.
> > Then I download the Mapguide server an Mapguider server extensions
> > and I build the OEMcomponents. This also seems to compile fine.
> > IMake 1.0: Build Successful ........................
> > Done building OEM components .......................
> > Then I go and try to build and install the default configuration:
> > aclocal    I get this:
> > acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
> >   run info '(automake)Extending aclocal'
> >   or see
> > http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > acinclude.m4:12: warning: underquoted definition of MAP_SUBST
> > acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
> > acinclude.m4:25: warning: underquoted definition of
> MAP_GEN_CONFIG_VARS
> > acinclude.m4:67: warning: underquoted definition of
> > MAP_GENERATE_MAKEFILES
> > acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
> > acinclude.m4:83: warning: underquoted definition of
> > MAP_DEFINE_TYPE_RLIM_T
> > acinclude.m4:108: warning: underquoted definition of
> > MAP_SUBST_EXPANDED_ARG
> > acinclude.m4:115: warning: underquoted definition of
> > MAP_EXPORT_ARGUMENTS
> > libtoolize --force OK
> > automake --add-missing --copy   OK
> > autoconf    OK
> > ./configure   OK
> > make OK
> > make check OK
> > make install  get into troubles... After lot of messages I start
> > getting errors, this is the first one:
> > BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
> > BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete type
> > And I can not continue following the instructions :(
> > Anybody can help?
> > Thanks in advance.
> > Javier.
> > - To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
