[mapguide-users] install problem Mapguide Studio preview 2007
Bart van den Eijnden (OSGIS) bartvde at xs4all.nl
Wed May 10 15:03:30 EDT 2006
Apparently I had version 2.0 beta2 installed of the .NET framework,
which caused the problems. Uninstalling it solved my problem.
When running the .NET installer by itself I got correct feedback (see
attachment), but using the installer embedded in Autodesk Studio preview
I did not get the correct feedback. Is there a way to handle this issue
with the Studio installer and to get the window to display as well
instead of the error code returned by the .NET installer in a log file?
Best regards,
Bart
Chris Gountanis wrote:
>Try installing .Net 2.0
>http://www.microsoft.com/downloads/details.aspx?FamilyID=7abd8c8f-287e-4c7e-
>9a4a-a4ecff40fc8e&DisplayLang=en
>Chris Gountanis
>Programmer/Analyst - Network Administrator
>cgountanis at mpower-tech.com
>MPOWER TECHNOLOGIES
>501 S Nicolet Road Appleton, WI 54914
>Office Number: 877.269.6971
>www.mpower-tech.com
>Making complex information more accessible.
>-----Original Message-----
>From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
>Sent: Tuesday, May 09, 2006 2:04 PM
>To: users at mapguide.osgeo.org
>Subject: [mapguide-users] install problem Mapguide Studio preview 2007
>Hi list,
>I am trying to install the Studio preview 2007 on my Windows XP Home
>Edition, but the installation aborts when installing the support components.
>The log file to which the program refers (MgStudioSetup.log) says:
>2006/5/9:20:57:13    bart    OSGIS    === Installation started on OSGIS
>by bart ===
>2006/5/9:20:57:22    bart    OSGIS    Install    MSI Runtime 3.1
>Skipped    Windows Installer upgrade is not required. System Version =
>3.1.4000.2435
>2006/5/9:20:57:31    bart    OSGIS    Install    .NET Framework Runtime
>2.0    Failed    Installation aborted, Result=1603
>2006/5/9:20:58:37    bart    OSGIS    === Installation ended ===
>Any ideas on how to fix this? Thanks.
>Best regards,
>Bart
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
OSGIS, Open Source GIS
http://www.osgis.nl
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060510/d0519919/DOTNET20.png
More information about the Mapguide-users mailing list
