extended feature source and selection
Charles rambo mach724 at hotmail.com
Fri Nov 3 05:40:19 EST 2006
Hi to all,
I have a problem when I want to select an object of which its layer uses an
extended feature source.
This extended feature source is an Access data file and the layer come from
a .shp file.
I use this script to select my object:
$resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
$featureService =
$siteConnection->CreateService(MgServiceType::FeatureService);
$map = new MgMap();
$map->Open($resourceService, $mapName);
$queryOptions = new MgFeatureQueryOptions();
$queryOptions->SetFilter("RNAME LIKE 'Schmitt%'");
$featureResId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Data/Parcels.FeatureSource");
$layer = $map->GetLayers()->GetItem('Parcels');
$layerClassName = $layer->GetFeatureClassName();
$featureReader = $featureService->SelectFeatures($featureResId,
$layerClassName, $queryOptions); //"Parcels" or extended feature source
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 0);
$selectionXml = $selection->ToXml();
echo 'Setting selection...';
This program works fine when I use the feature class without extended source
(the object is highlighted).
It doesn’t work when I use an extended feature source.
Is something missing in this script?
Thanks
Charles
_________________________________________________________________
Windows Live Spaces : créez votre Space à votre image !
http://www.windowslivespaces.fr/
More information about the Mapguide-users mailing list
