[mapguide-users] NamedCollection reference
Jason Birch Jason.Birch at nanaimo.ca
Fri Nov 3 16:37:46 EST 2006
I could be wrong, but I don't know of many people who have chosen to support both viewers.  This may be why you're not seeing much help with this particular problem.
It should be possible for you to deal with this though.  I can't say that I have any experience in this area, which will probably show in my questions.
Where are the scripts stored?  Are they entered directly into studio, or do they reside in your application template?
Would it be possible to keep the script attached to the select button, but to have it call a function that you have in your application page, and then have the application page either make this a real script or a stub based on what the viewer type is?
How are you allowing the user to select between the viewers?
Jason
Sent: Fri 2006-11-03 1:15 PM
Subject: RE: [mapguide-users] NamedCollection reference
I finally found the problem here.  Slight typo on my part <redface>.
I finally got the tool working as desired with both the ajax and dwf viewers.<I feel like im having a conversation with myself here : ) >
Anyways, I do have a related question...  Due to the difference in which the AJAX and DWF viewers deal with selections, I had to implement the commands differently - AJAX as a Script and DWF as a URL.  I can hide the DWF URL command from the AJAX viewer because Invoke URL action supports this, but I cannot hide the AJAX SCRIPT command from the DWF viewer as Invoke Script doesn't seem to support this.
Is there some other way (programatically perhaps?) that I can hide a Script command based on the client's viewer?
Greg
Sent: Friday, November 03, 2006 10:12 AM
A little more info on my problem here:
I am working though the examples in ch 3 of the dev guide - working with the active selection - for both the dwf and ajax viewers.
I have 2 pages or functions - one for each viewer - and the code is the same in both cases with the exception of the single line of code that gets the selection from the map.  As the dev guide explains, this is due to the different manner in which the dwf and ajax viewers deal with selections.
So, my DWF example is working.  I can select a feature on my map, and return feature data to my task pane.  My AJAX example isn't working, and I still get the error below.
Seems rather odd, since the code is the same with the noted exception.
Any insight here?
Greg
Sent: Thursday, November 02, 2006 4:52 PM
Subject: [mapguide-users] NamedCollection reference
I am getting the following error when loading a mg page that retrieves feature properties from a selected feature.
Duplicate object.Duplicate object. Exception occurred in method CheckDuplicate at line 491 in file c:\build_tux_area\mgdev_opensource\common\service\data\NamedCollection.cpp
How do I go about troubleshooting this?
Greg Knight
The substance of this message, including any attachments, may be
confidential, legally
privileged and/or exempt from disclosure pursuant to Massachusetts
law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and
delete the material from any computer.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061103/fd37e330/attachment.bin
More information about the Mapguide-users mailing list
