[mapguide-users] Permissions problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Wed Nov 8 08:44:12 EST 2006
Thanks
Walt Welton-Lair wrote:
> No problem, I updated it.
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Wednesday, November 08, 2006 2:15 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Permissions problem...
> Too late...I submitted it last night, and don't see a way to edit it.
> It's MG446 if you (or anyone else watching this thread) has the means
> to edit it....
> Andrew
>> Thanks.  In the artifact please include the final diagnosis below.
>> -----Original Message-----
>> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> Sent: Wednesday, November 08, 2006 4:37 AM
>> To: users at mapguide.osgeo.org
>> Subject: Re: [mapguide-users] Permissions problem...
>> Sounds about right......at least I know I'm not missing something
>> obvious. I'll submit an artifact...
>> Andrew
>>> I tested this a little more, and here's what I found.
>>> When opening a web layout using AJAX viewer, the login prompt appears
>>> immediately, before *any* server request is even made.  The first
>>> server operation then ends up being an authentication request
>>> (OpAuthenticate).  After this come the requests for resources - the
>>> web layout, etc.  These succeed because we have provided credentials.
>>> When opening a web layout using DWF viewer, the behavior is
>>> different.  There's a couple of authentication requests that get made
>>> using "anonymous" user, but no login prompt has yet been displayed.
>>> Then comes a request to get the web layout resource, again using
>>> "anonymous".  This fails because user "anonymous" does not have access
>>> to the library.  The browser then displays the exception message.
>>> At this point the web layout hasn't been loaded and DWF Viewer hasn't
>>> even entered into the picture.  So this is a MapGuide web tier
>> issue...
>>> Walt
>>> *Sent:* Tuesday, November 07, 2006 6:29 PM
>>> Ya, that's sort of what I figured was happening....that it's not
>>> asking me to log in, because it doesn't have permission to ask...which
>>> is a bit silly. If that's the case, then it's a fairly annoying
>> bug....
>>> Andrew
>>>> So it's a question of order.  Should MapGuide first authenticate
>>>> before it tries to access the resource (and find out that you don't
>>>> have permission)?  It looks like it does it the other way - it checks
>>>> whether you have permission before authenticating.  I don't know the
>>>> right answer.
>>>> I do know that the DWF Viewer code which handles the HTTP request
>>>> knows nothing about MapGuide and doesn't know what to do with the
>>>> permission denied response.
>>>> Walt
>>>> *Sent:* Tuesday, November 07, 2006 6:15 PM
>>>> Ah...sorry. I should have posted the error that it gives me.....When
>>>> I try to use the DWF Viewer, this is what I get:
>>>> Permission denied to resource: Library://test/
>>>> Permission denied to resource: Library://test/ Exception occurred in
>>>> method MgResourceHeaderManager.CheckPermission at line 2495 in file
>> c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
>> HeaderManager.cpp
>>>> Andrew
>>>>> So DWF Viewer doesn't prompt for credentials.  Do you get back any
>>>>> data or does it just sit there?
>>>>> Ultimately DWF Viewer simply makes a Mapping Service GetMap HTTP
>>>>> request via WinINet.  It prompts for credentials when it gets a 401
>>>>> response to that initial request, and then resubmits the GetMap
>>>>> request.  If it just sits there that means it didn't get a 401
>>>>> response and it thinks it's done.
>>>>> Walt
>>>>> *Sent:* Tuesday, November 07, 2006 4:53 PM
>>>>> *Subject:* [mapguide-users] Permissions problem...
>>>>> I've got a project that I want to password protect....I've given a
>>>>> specific MapGuide User read permissions to my library (removed
>>>>> 'Everyone', and added 'Administrator' as read/write as well). What's
>>>>> happening now is that the DWF viewer isn't asking me to log in. If I
>>>>> change my URL to use the AJAX viewer, it works fine (asks me to log
>>>>> in, and then works as it should). So, for example:
>>>>> http://host/mapguide/mapviewerdwf/?WEBLAYOUT=.....   ----This does
>>>>> NOT work
>>>>> http://host/mapguide/mapviewerajax/?WEBLAYOUT=.....   ----This DOES
>> work
>>>>> This happens on any PC that I've tested it on. Am I missing
>>>>> something here, or is this a bug? I'm using v1.0.2.17861 (the latest
>>>>> release).
>>>>> Andrew
>>>>> 	*Andrew DeMerchant*
>>>>> *Computer Technologist*
>>>>> ph.1-877-2GEMTEC x.163
>>>>> fax 506-453-9470
>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>> /191 Doak Road
>>>>> Fredericton, NB, Canada
>>>>> E3C 2E6
>>>> 	*Andrew DeMerchant*
>>>> fax 506-453-9470
>>>> /191 Doak Road
>>>> E3C 2E6
>>> 	*Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
