[mapguide-users] DWF files and Hyperlinks
Jorge Rubio j.e.rubio at gmail.com
Thu Nov 9 09:09:09 EST 2006
Thank you Walt, now works fine.
However, I would like to see all dwg layers to turn them on-off as well as
hyperlinks.
Is it possible or should I change my approach to the problem?
2006/11/8, Walt Welton-Lair <walt.welton-lair at autodesk.com>:
>  In your weblayout, try changing the hyperlink target to something other
> than "Task pane".  That might help.
> Also make sure you're not inadvertently using relative hyperlinks.  Make
> sure they're prefixed with "http://" if they're external links.
> *From:* Jorge Rubio [mailto:j.e.rubio at gmail.com]
> *Sent:* Wednesday, November 08, 2006 10:04 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] DWF files and Hyperlinks
>  Hi, friends!
> I have a dwf file with many hyperlinks to diferent kind of documents, xls,
> doc, pdf, jpg and dwf.
> When i open it with Autodesk DWF Viewer 7 I browse all the files without
> problem.
> I have created a Web.Layout to be used with MGOS.
> If I use MGOS with AJAX viewer, I can't "see" any hyperlinks; they are
> lost.
> If I use MGOS with DWF viewer, it tries to open files at the task pane,
> but doesn't found them.
> How can I fix this problem.
> Thanks in advance.
> Lic. Jorge Rubio
Lic. Jorge Rubio
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061109/9eef01f2/attachment.html
More information about the Mapguide-users mailing list
