[mapguide-users] Sheboygan not seen in administrator's 'load package'
Bill Dhimitri bill.dhimitri at autodesk.com
Fri Nov 10 13:49:37 EST 2006
Hi Jay,
I have done this (putting mgp files into the Packages folder) many
times, and it has always worked for me except when:
- I sometimes reverse the letters in mgp to mpg.
- I put the file in one folder, but the MapGuide Admin is connected to a
copy of the server in a different folder or even on a different machine.
To check for the second case, you might try to do a "create package"
operation and see if the MapGuide Admin writes the mgp file to the
folder that you expect.
Bill
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, November 10, 2006 11:47 AM
Subject: RE: [mapguide-users] Sheboygan not seen in administrator's
'load package'
Are you copying the .mgp file into the same "Packages folder" as defined
under Configure Services in MapGuide Administrator?
Andy
  _____
Sent: Friday, November 10, 2006 6:07 AM
Subject: [mapguide-users] Sheboygan not seen in administrator's 'load
package'
Hello,
Installed MG (version 1.0.2.17861) and tested pursuant to
Documentation-' Installing and configuring on windows'.  All seems fine
so far.  My problem is trying to load sample data package Sheboygan
pursuant to Documentation-'Installing sample data and viewer sample
application'.  The Sheboygan down load entitled 'Sheboygan .mgp' is
apparently zip, I've put it in the correct location, renamed its
extension to .mgp, and yet in the 'Load Packages section' it still is
not listed. It appears that for some reason it is not recognized. I have
tried on 2 machines with same results. I think its something rather
simple that I am just missing. Appreciation in advance...
Jay
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061110/6ec57749/attachment.html
More information about the Mapguide-users mailing list
