[mapguide-users] Use Oarcle XE with Autodesk MAP, MapGuide and King.Oracle provider
Haris Kurtagic haris at sl-king.com
Mon Nov 13 09:32:52 EST 2006
Hi Brad,
Thanks for compliments.
Certainly I wouldn't do any hidden clicks in demo :)
Yes, it is that dynamic, any change is immediately in database, you
don't need any "Save Back" or something like that.
Haris
Sent: Monday, November 13, 2006 3:25 PM
Subject: RE: [mapguide-users] Use Oarcle XE with Autodesk MAP, MapGuide
I have the same response Haris, GOOD JOB!
Question? In the movie Mapguide + Oracle XE + King.Oracle you show the
eidt in map and then that edit being in mapguide. However there is
nothing about an update or a sqve or a send to source after doing the
move in map. Is the system that dynamic? Or did that mouse move not show
up?
Brad
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Friday, November 10, 2006 11:26 PM
Subject: Re: [mapguide-users] Use Oarcle XE with Autodesk MAP, MapGuide
good work haris, 'THE' best tutorial for beginers,
Think you need to mention the installation of instant client or add a
clip to this movie ?
Shailesh
----- Original Message -----
From: Haris Kurtagic <haris at sl-king.com> <mailto:haris at sl-king.com>
To: <users at mapguide.osgeo.org> <mailto:users at mapguide.osgeo.org>
Cc:
Date: Friday, November 10 2006 07:48 PM
Subject: [mapguide-users]
Here is flash movie demonstrating how you cane use all this stuff
together.
Idea of movie is to show hot to Install Oracle XE, Transfer SHP data to
it, Edit and Query using Autodesk MAP and MapGuide.
http://www.sl-king.com/fdooracle/KingOracleXE/MapOracleXeKingOracle.html
I hope someone will find this useful and I would appreciate if you share
with me your thoughts if this kind of movies are right way to share
information's.
Demo uses latest provider King.Oracle v0.4.4 www.sl-king.com/fdooracle
and Fdo2Fdo v0.2.3 www.sl-king.com/fdo2fdo
Haris <http://www.sl-king.com/fdooracle/>
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061113/6dfcc068/attachment.html
More information about the Mapguide-users mailing list
