[mapguide-users] checking wms connections
Andy Morsell amorsell at spatialgis.com
Mon Nov 13 11:29:25 EST 2006
What do you get from this?
Also attached is an email from Thomas Tuerke from July that has handy little
wms client test page in it.  I hope it comes through on the email list.
-----Original Message-----
From: joanne cook [mailto:j.cook at oxfordarch.co.uk]
Sent: Monday, November 13, 2006 7:40 AM
Subject: [mapguide-users] checking wms connections
Hi All,
I am trying to make a wms connection to some layers in my MapGuide
OpenSource 1.0.2 map. I can't connect to my own, and assume there's some
kind of problem with the conversion from a different coordinate system, as
seems to have been discussed at length on this list, so I thought I'd better
try the Sheboygan data first. All I am trying to do is connect to the data
in Firefox 2, using the following URL:
This gives me the following message:
An unclassified exception occurred.
An unclassified exception occurred. Exception occurred in method
MgHttpWmsGetMap.Execute at line 204 in file
If I remove any of the parameters I get an xml document back that tells me I
don't have all the parameters I need. A GetCapabilities request seems to
validate as far as I can tell...
The end result of all of this is that I want to be able to use my MapGuide
Open Source data in OpenLayers, but needless to say that doesn't work at all
at the moment either!
Many thanks
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl -
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
An embedded message was scrubbed...
From: "Thomas M. Tuerke" <thomas.m.tuerke at autodesk.com>
Subject: RE: [mapguide-users] Having trouble figuring out the path for wms
Date: Wed, 5 Jul 2006 11:50:11 -0800
Url: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061113/3c93df4b/attachment.mht
More information about the Mapguide-users mailing list
