[mapguide-users] SDF into DWG or SHP
Brad Nesom kidsmake6 at msn.com
Mon Nov 13 11:50:13 EST 2006
Map 2007 will import/export either version of sdf.
Depending on where you select the import/export from.
The file pulldown or the map pulldown or the commandline _MAPSDFIN is the
sdfv2. (
<mk:@MSITStore:C:/PROGRA~1/AUTODE~1/help/acmap.chm::/WSfacf1429558a55de7bedc
1019295baf0-7288.html> MAPIMPORTMAPGUIDE (Same as MAPSDFIN))
<mk:@MSITStore:C:/PROGRA~1/AUTODE~1/help/acmap.chm::/WS73099cc142f487559a28e
8107bdfefbd9-669d.html> MAPEXPORTMAPGUIDE (Same as MAP2SDF))
>From the display manager select the one layer you want an sdf for. Select
tools export layer. ( cannot find a command line or api version of this
other that the below.)
http://images.autodesk.com/adsk/files/dwgtosdf3.pdf
I assume that SDFLoader will not come over to the MGOS/MGENT from the 6.5
realm. (As it presently only does sdf2)
  _____
From: Kim Woynowskie [mailto:kimw at ci.grandjct.co.us]
Sent: Monday, November 13, 2006 9:18 AM
Subject: Re: [mapguide-users] SDF into DWG or SHP
Maciej
What version of SDF, autodesk Map will import SDFv2 to dwg, not sure about
SDF +3 files
Maciej Skorczewski <maciej.skorczewski at procad.pl>
To:
<users at mapguide.osgeo.org>
Date:
Sunday, November 12, 2006
Subject:
Hi
Sorry if this post is not in topic of this group but i think that
someone can know that.
Problem is: Is it posible to convert SDF files into DWG or SHP (so can i
edit it ex in CAD?)
Maciej Skorczewski
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061113/2aeb9027/attachment.html
More information about the Mapguide-users mailing list
