[mapguide-users] capturing map image
Andy Morsell amorsell at spatialgis.com
Thu Nov 16 02:32:16 EST 2006
The pushpin you are talking about is created as part of a users session,
right?  If so, then, yes, you would need to use the session to retrieve the
map if you want to view it.  If you need to do this with no user
interaction, then you should be able to perform all of the steps
programmatically, but you will need to establish a session as part of that
programming.
Andy
-----Original Message-----
Sent: Wednesday, November 15, 2006 10:18 PM
Subject: Re: [mapguide-users] capturing map image
Hi andy,
i got one question, is that possible to set the push pin image location at
the same time while you get the map image?because if i didn't use the
session parameter, i can't view the push pin on the specific area.
pardon me if my explanation/english is bad.
I hope you can help me out..thank you
regards,
Kencana
Andy Morsell wrote:
> I just responded to this same question that you posted at the autodesk
> MapGuide Enterprise discussion group.  More information on this can
> also be found by searching the archives here.
> The easiest way to do this would be to use the GETMAPIMAGE mapagent
> operation.  Here is an example URL:
> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=GETMAPIMAGE
> &VERSION=1.0.0&MAPNAME=Sheboygan&LOCALE=en&MAPDEFINITION=Library://Sam
> ples/Sheboygan/Maps/Sheboygan.MapDefinition&FORMAT=PNG&SETDISPLAYDPI=3
> 00&SETDISPLAYWIDTH=800&SETDISPLAYHEIGHT=600&SESSION=6137915c-0000-1000
> -8000-005056c00001_en
> In this case, the one thing you do need to determine or
> programatically create is a session.  That is required.  The above URL
> will return a map representation of how that map looked when the user
> last zoomed or panned, including any selected objects.  So, it's a
> good way to take an existing user map session and produce an image of what
they were looking at.
> There are some other optional override parameters so that you can set
> the map center, height and width without an existing session.  They are:
> SETVIEWCENTERX=
> SETVIEWCENTERY=
> SETVIEWSCALE=
> In this case, you don't need a SESSION parameter, but you will need to
> supply credentials.  You can use the below undocumented parameters so
> the user is not presented with the challenge/response dialog:
> USERNAME=
> PASSWORD=
> Here is a full example:
> &VERSION=1.0.0&MAPNAME=Sheboygan&LOCALE=en&MAPDEFINITION=Library%3A%2F
> %2FSamples%2FSheboygan%2FMaps%2FSheboygan.MapDefinition&FORMAT=PNG&SET
> VIEWCENTERX=-87.73&SETVIEWCENTERY=43.74&SETVIEWSCALE=5000&SETDISPLAYDP
> I=300&SETDISPLAYWIDTH=3000&SETDISPLAYHEIGHT=2100&USERNAME=Anonymous&PA
> SSWORD=
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> Kencana wrote:
>> hi all,
>> I got one question about exporting the map image into jpg or png or
>> any image format file.Can I know how to do it?I hope somebody can
>> help me out...thank you
>> regards,
>> kencana
View this message in context:
http://www.nabble.com/capturing-map-image-tf2627292.html#a7372263
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
