wfs problem?
joanne cook j.cook at oxfordarch.co.uk
Fri Nov 17 09:25:24 EST 2006
Hi All,
I am trying to set up MapGuide OpenSource as a wfs server, and when I tried a simple GetCapabilities request using this url:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?request=getCapabilities&service=wfs&version=1.0.0
I got the following response:
An exception occurred in FDO component. XML Document parse error at line 6 column 7: Expected end of tag 'br'
An exception occurred in FDO component. XML Document parse error at line 6 column 7: Expected end of tag 'br' Exception occurred in method MgFdoConnectionManager.Open at line 798 in file c:\build_tux_area\mgdev_opensource\server\src\common\manager\FdoConnectionManager.cpp
Is this a bug, or "user error"?
When I try the following request I get a different error:
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?request=getfeature&service=wfs&version=1.0.0&typename=Samples/Sheboygan/Data/BuildingOutlines&outputformat=SHAPE
The coordinate system conversion failed. Unsupported coordinate system code.
The coordinate system conversion failed. Unsupported coordinate system code. Exception occurred in method MgCoordinateSystem.ConvertCoordinateSystemCodeToWkt at line 950 in file c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\CoordinateSystem.cpp
The sample dataset says it's in EPSG:4326, so there shouldn't be any conversion, should there?
Thanks
Jo
Joanne Cook BSc MLitt AIFA MBCS
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl - www.blackspider.com
More information about the Mapguide-users mailing list
