[mapguide-users] Query for Oracle SDO Data without using SDO_FILTER
Traian Stanev traian.stanev at autodesk.com
Fri Nov 17 12:15:55 EST 2006
When viewing maps/layers in MapGuide there will always be a spatial
query, regardless of the data source. The only way to change this
(currently) would be to edit the source code -- the relevant section is
in StylizationUtil::ExecuteFeatureQuery(). I agree it would be nice to
be able to set something in the layer that skips the spatial query -- it
would be nicer still if Oracle didn't need workarounds in order to,
well, work.
Traian
-----Original Message-----
From: Johann Nothbauer [mailto:nothbauer at rmdata.at]
Sent: Friday, November 17, 2006 6:55 AM
To: OSGEO Mapguide Users
Subject: [mapguide-users] Query for Oracle SDO Data without using
SDO_FILTER
Is there any way to prevent Mapguide from using the SDO_FILTER()=='TRUE'
- Clause for Layers of Oracle Spatial Feature Sources?
I'm trying to produce an overview layer from an Oracle table containing
a lot of Line Features (> 2 million). The Features, that should be part
of the overview can be found with a very simple predicate (e.g.: "where
layername = 'GG'") and are very few (< 1000). My problem is, that
Mapguide always sends a combined query (simple predicate plus spatial
query with "extent all"). The Oracle explain plan shows, that internally
ALL Features are fetched into memory as a result of the spatial query
only to be filtered with the much "better" simple predicate.
I see this is a problem of the Oracle Cost Based Optimizer.
A nice workaround could be a "Don't use Spatial Filter" Checkbox in
Mapguide (as available in Oracle Mapviewer).
Would this be possible for the currrent Design?
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
