[mapguide-users] WMS Provider on Linux?
Andy Morsell amorsell at spatialgis.com
Fri Nov 17 13:39:03 EST 2006
Thanks Jason, but that was included as part of the build process.  Tom's
instructions at
http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_4 includes
that step. I have other third party providers, such as GDAL, working fine on
the same installations.
Andy
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, November 17, 2006 10:32 AM
Subject: RE: [mapguide-users] WMS Provider on Linux?
I don't think that the MapGuide installation instructions that I looked at
told you that you had to run the install option against the build_thirdparty
script as well as the build script.  This messed me up on Windows anyway.
Jason
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, November 17, 2006 10:27
Subject: [mapguide-users] WMS Provider on Linux?
I recently built FDO 3.2 and MapGuide Open from subversion on Fedora 4.
When I built FDO, I included all of the optional data providers.  Everything
seemed to build fine.
But, when I try to create a layer using the WMS Provider, I get the
following error at the server:
An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 201 in file
FdoConnectionManager.cpp
In the fdo-3.2.0 directory, there are a number of libWMS* files and
providers.xml does have an entry for the WMS provider.  I am experiencing
this same problem on two different Fedora 4 boxes.
Thanks.
Andy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061117/43001b8f/attachment.html
More information about the Mapguide-users mailing list
