[mapguide-users] Weird Error when restarting server on Linux
Michaela Schneeberger michaela.schneeberger at eur.autodesk.com
Fri Nov 24 03:41:31 EST 2006
I got problem with the OGR provider in Autodesk Map 3D 2007.
The provider is working fine for Oracle and SHP-files, but if I try to
connect MapInfo TAB or MIF/MID-files the following error message
appears.
Autodesk.Gis.Common.Exception: Connect failed
            By Autodesk.Gis.Fdo.Connections.IConnectionImp.Open()
Autodesk.Gis.Map.DataConnect.Plugins.GenericProviderConnectionPlugin.but
tonPendingConnect_Click(Object sender, EventArds e)
Any idea why this error occurs?
Thanks
michaela
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061124/9cd67ee0/attachment.html
More information about the Mapguide-users mailing list
