[mapguide-users] MapGuide Studio and DXF / DWG problems....
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Nov 24 13:50:57 EST 2006
Ok, so I did reinstall Studio....my crashing problem is gone (I didn't
try re-applying SP1 - only reason that I did in the first place was to
see if it would fix my problem). Still get the DBX CAS 4 error
though.....I even totally cleaned my registry of anything to do with
Studio (and there was a ton of stuff after uninstalling that didn't get
removed).
Andrew
Andrew DeMerchant wrote:
> I'm not about to try uninstalling my CAD apps here to make Studio
> work, so I haven't done that....but other than that, ditto for me. I
> see the load sequence and that seems to work....dete.exe starts
> running and everything. But then you instantly get the cas error when
> you try to load the resource.
> Interestingly enough, today it's totally crashing my studio when I try
> to load a dxf....that's a first for me. I pick my DXF and it
> crashes...every time. I had installed SP1 yesterday, and it wasn't
> crashing....it's got to be because of that though, since I've never
> had a problem like that.
> The registry thing sounds logical enough....maybe I'll try to
> uninstall Studio today. I'll do the same as Gord and have a look for
> reg keys that don't get removed on the uninstall....
> Andrew
> Dave Wilson wrote:
>> Based on earlier threads from Bill D it may be related to registry
>> entries and items from earlier versions.
>> On the other machines did you have any previews installed or just the
>> release stuff? I suspect that on the working machines you never had any
>> Studio previews installed.
>> Dave
>> -----Original Message-----
>> From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
>> Sent: Friday, November 24, 2006 10:07 AM
>> To: users at mapguide.osgeo.org
>> Subject: RE: [mapguide-users] MapGuide Studio and DXF / DWG problems....
>> Mapguide was first in my case and no I don't run them at the same time.
>> I have uninstalled Map2007 and studio and then re-installed Studio with
>> no change in results.
>> When I run Studio I watch the status line and it goes through the entire
>> load sequence and after loading managedmapapi it says opening test.dwg
>> and immediately gives the dbx cas4 4 error.
>> I can see the load sequence happening on a machine that works and it is
>> the same sequence.
>> From: Dave Wilson [mailto:dave.wilson at autodesk.com]
>> Sent: Friday, November 24, 2006 10:01 AM
>> Which product was installed first? I assume MapGuide was last?
>> You aren't running both apps at the same time are you? You can only run
>> 1 MapGuide instance when doing DWG imports because of the underlying
>> Autocad engine that is loaded. That would imply you can't run Map or
>> Civil at the same time either. If it's not a runtime problem then it has
>> to be DLL's.
>> Dave
>> Sent: Friday, November 24, 2006 9:57 AM
>> Andrew,
>> Sorry I misread your post a little.  The 2d/3d issue is not with DXF it
>> is with DWF.  I was having a problem with both but the DWF was just the
>> 3d issue.
>> I have AutoCAD Map 3d 2007 on my machine.  However, I have tried it
>> successfully on other machines that have the same version of the
>> software and it works fine.
>> There is definitely something strange going on here because you are the
>> third person I know who has this issue.  Not sure how Autodesk resolves
>> it if they cannot reproduce the problem.
>> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> Sent: Thursday, November 23, 2006 8:12 PM
>> Subject: Re: [mapguide-users] MapGuide Studio and DXF / DWG problems....
>> After posting here, I did think to go check the Autodesk groups and saw
>> your post (with no solution). I don't see why they're be any 3D info in
>> my dxf, but I'll give it another shot tomorrow and make sure it's 2D
>> only.
>> As for the version, this has happened with all versions available from
>> the Autodesk website. Currently I'm using the latest one with SP1......I
>> should also note that I've got AutoCAD Land Desktop and Civil 3D
>> installed on my PC.....conflicting dll's sounds to me like a pretty
>> logical problem.....the only question is how to fix it!
>> Andrew
>> Gord McKenzie wrote:
>>> I have the same issue and error.  If you look on the Mapguide
>>> newsgroups on the Autodesk news server, you will see I have posted to
>>> separate messages about this problemThe first time Bill Dhimitri tried
>>> to give some helpful suggestions but they did not work.  The second
>>> time I asked, after applying SP1, I got no replies.  I have had this
>>> problem on my notebook since day 1.  I have a client who purchased
>>> Studio and they have the same problem.  I have tried installing the
>>> Studio software on a couple of other machines in the office and it has
>>> worked fine for DWG data.  The drawings are not the issue as I can use
>>> the same DWG on one machine and it works but not on another.  There is
>>> something amiss here but no luck so far from Autodesk.  .  General
>>> Autodesk knowledge base alludes to this being an ARX/DLL conflict or
>>> version error of some sort.
>>> FYI, I found that if you have a 2d DWF you can work with it in Studio.
>>> If it is a 3d DWF it will not work.
>>> So far I cannot find anything to answer the problem.
>>> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
>>> *Sent:* Thursday, November 23, 2006 2:18 PM
>>> *To:* users at mapguide.osgeo.org
>>> *Subject:* RE: [mapguide-users] MapGuide Studio and DXF / DWG
>> problems....
>>> MapGuide Studio will allow you to import DWG files and convert them
>>> either to SDF or DWF. If you have a sample DWG and DXF that generates
>>> this error could you attach it? Maybe change the extension on the
>>> files to ensure they won't get filtered out by email. I'm not 100%
>>> sure on the DXF files.
>>> What version of Studio do you currently have?
>>> Dave
>>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>>> *Sent:* Thursday, November 23, 2006 1:20 PM
>>> *Subject:* [mapguide-users] MapGuide Studio and DXF / DWG problems....
>>> Has anyone been able to import DXF or DWG files using MapGuide Studio
>>> (any version)? No matter what version of Studio (this happened in all
>>> of the demo versions) I use, and no matter what dxf or dwg file I try
>>> to bring in, I always get a fatal error msgbox that pops up and says
>>> "DBX CAS 4".....useful. You would think, being an Autodesk product,
>>> that Studio would actually be able to bring in AutoCAD files in some
>>> form, rather than just DWFs.....anyone else get this to work?
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
