about the version of bison
zz dazao2001cn at yahoo.com.cn
Mon Nov 27 09:13:22 EST 2006
Hi all
When I built FDO , errors appeared as follws:
.\src\geometry\Parse\yyAwktWin.cpp(1038) : error C2143: syntax error :
missing ';' before '->'
.\src\geometry\Parse\yyAwktWin.cpp(1038) : error C2082: redefinition of
formal parameter 'pParse'
.\src\geometry\Parse\yyAwktWin.cpp(1042) : error C2143: syntax error :
.\src\geometry\Parse\yyAwktWin.cpp(1042) : error C2082: redefinition of
the corresponding program code is as follows:
short int *pParse->gis_awkt_yyssp;
GIS_AWKT_YYSTYPE *pParse->gis_awkt_yyvsp;
I use Bision 2.1 to build FDO, however, OpenSourceBuild__README.txt tells
that FDO has been tested using Bison 1.875. Is the errors caused by the
version of bision?  Can anyone point me towards finding the cause of this
problem?
thanks
zz
View this message in context: http://www.nabble.com/about-the-version-of-bison-tf2711945.html#a7560611
More information about the Mapguide-users mailing list
