[mapguide-users] RE: digitizing features
Kencana bluesky_dyx at hotmail.com
Thu Nov 30 02:30:01 EST 2006
I have successfully create the circle and rectangle by using the redlining
code.
any idea for creating polygon?
I thought it will be easy to create the polygon but I guess I was wrong.
Thank you very much
Regards,
Kencana
Andrew DeMerchant wrote:
> Not having looked at this yet, I have no idea.....but I would start by
> looking at the code for redlining to see how that's done, because
> basically that's what you want to do.
> Andrew
> Kencana wrote:
>> Hi Andrew,
>> Thank you for your reply.
>> if I combine the redlining code with the digitizing code,
>> how can it possible to draw a circle?
>> I think if for rectangle and polygon it is still possible.
>> Any idea of the circle?
>> Thank you once again for the reply.
>> Regards,
>> Kencana
>>> I was wondering the same thing a while back, and was going to try to
>>> somehow combine what's in the redlining example on that site with the
>>> digitizing sample......but I still haven't gotten around to it. You
>>> might take a look at the redlining code though...
>>> Andrew
>>> Kencana wrote:
>>>> Hi Dhimitri,
>>>> Thanx for the reply.Yah, I have tried the code and it works
>>>> successfully.
>>>> however, when i use digitize circle, the circle will directly dissapear
>>>> once
>>>> user
>>>> finish drag the circle range. what i mean is,
>>>> how to make the circle being displayed on the map so that user
>>>> know which area they have selected.
>>>> Do you have any idea on this?
>>>> because this thing can be done in mapguide 6.5
>>>> I was wondering whether it can be done in mapguide enterprise or not.
>>>> Thank you very much once again for the reference
>>>> Regards,
>>>> Kencana
>>>> Bill Dhimitri wrote:
>>>>> Hi Kencana,
>>>>> I think this sample will have what you are looking for:
>>>>> http://data.mapguide.com/mapguide/devguide/index.php
>>>>> Note that the site itself provides the source code for how to do it.
>>>>> Bill
>>>>> -----Original Message-----
>>>>> From: Kencana [mailto:bluesky_dyx at hotmail.com]
>>>>> Sent: Tuesday, November 28, 2006 2:38 AM
>>>>> To: users at mapguide.osgeo.org
>>>>> Subject: [mapguide-users] digitizing features
>>>>> Hi all,
>>>>> Is that possible to keep the circle or rectangle or etc. when you
>>>>> digitize
>>>>> circle the map?
>>>>> because as I try out the developer sample-digitizing code,
>>>>> the circle will directly dissapear once user finish drag it.
>>>>> any idea of this?
>>>>> Thank you very much
>>>>> Regards,
>>>>> Kencana
>>>>> View this message in context:
>>>>> http://www.nabble.com/digitizing-features-tf2716809.html#a7574656
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>>> 	*Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
View this message in context: http://www.nabble.com/digitizing-features-tf2716809.html#a7614809
More information about the Mapguide-users mailing list
