[mapguide-users] RE: mapguide install on FC4.
Tony Feng tonyutada at gmail.com
Wed Oct 11 06:17:28 EDT 2006
Maybe you can try to build and install the FDO alone, follow the
opensourcebuild_readme under source directory.
It should have no problem.
Best Regards:
Tony
-----Original Message-----
Sent: Monday, October 09, 2006 4:34 PM
Subject: [mapguide-users] RE: mapguide install on FC4.
Hi Nick,
Excuse me for the delay
I exec this steps on terminal window:
- export CC=gcc402
- export CXX=g++402
- export JAVA_HOME=/usr/lib/jvm/java-1.5.0-sun-1.5.0.06
- extract       fdo-3.1.0_R050.tar.gz    in  /home/OpenSource_FDO
- extract       mapguideaptinstaller-1.0.1.tar.gz    in
/usr/local/mapguideopensource
- cd /usr/local/mapguideopensource
- ./build_apt.sh -with-tomcat
the end there are this errors:
make[3]: Leaving directory `/home/OpenSource_FDO/providers/SDFPlus'
make[2]: Leaving directory `/home/OpenSource_FDO/providers/SDFPlus'
make[2]: Entering directory `/home/OpenSource_FDO/providers'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/OpenSource_FDO/providers'
make[1]: Leaving directory `/home/OpenSource_FDO/providers'
make[1]: Entering directory `/home/OpenSource_FDO'
make[1]: Nothing to be done for `all-am'.
make[1]: Leaving directory `/home/OpenSource_FDO'
- make install
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/home/OpenSource_FDO/providers/SDFPlus'
make[3]: Entering directory `/home/OpenSource_FDO/providers'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/OpenSource_FDO/providers'
make[2]: Entering directory `/home/OpenSource_FDO'
make[2]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/fdo-3.1.0/lib" || mkdir -p -- "/usr/local/fdo-3.1.0/lib"
 /usr/bin/install -c -m 644 'providers.xml'
'/usr/local/fdo-3.1.0/lib/providers.xml'
make[2]: Leaving directory `/home/OpenSource_FDO'
thaks Alba
Nick Sadowy wrote:
> Can you send me the error that you are seeing?  I don't remember off hand
> what I did to get it to install.  If I see the error, I will know what
> steps I took for FDO.
> I'll give gcc 4.0.2 a try.  Thanks for the suggestion.
> Nicholas Sadowy
> Sr. Information Manager
> CD-Data, Inc.
> 2330 E. Bidwell St, Suite 200
> Folsom, CA 95630
> (916) 817-2211 x106
> nick at cd-data.com
> http://www.cd-data.com
> From: alba [mailto:a.penitente at gepaspa.com]
> Sent: Monday, October 02, 2006 11:52 PM
> Subject: Re: [mapguide-users] mapguide install on FC4.
> Hi Nick
> also I had the same problems, but I have installed gcc 4.0.2 and not gcc
> 4.0.0 of FC4.
> now would want to ask I one what you?
> which are the steps that you have executed in order to install FDO 3.1
> and to make the date test?
> thank you
> Alba
> Nick Sadowy wrote:
>> Hi All.
>> I am having a heck of a time getting mapguide to compile all the way
>> through.  I have been able to overcome some hurdles by making the
>> individual packages that failed, but I haven't had any luck getting over
>> this latest issue:
>> During the make, I am getting the following error:
>> Making all in Service
>> `/usr/local/src/mapguide-1.0.1/Common/Service'
>> /bin/sh ../../libtool --tag=CXX --mode=link g++  -O2 -g -pipe -march=i386
>> -mcpu=i686 -fno-use-cxa-atexit -fexceptions   -o libMgCommon.la -rpath
>> /usr/local/mapguideopensource/lib -version-info 7:0:0
>> -L../../Oem/dbxml-2.2.13/install/lib -L../../Common/CoordinateSystem
>> ServiceControllerBuild.lo ServiceCoordinateSystemBuild.lo
>> ServiceDataBuild.lo ServiceExceptionBuild.lo ServiceGeometryBuild.lo
>> ServiceMapLayerBuild.lo ServiceNetBuild.lo ServiceServicesBuild.lo
>> ServiceSystemBuild.lo ServiceUtilBuild.lo -lxerces-c -lMgCoordinateSystem
>> ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
>> ../Security/libMgSecurity.a
>> *** Warning: Linking the shared library libMgCommon.la against the
>> *** static library ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a is
>> not
>> portable!
>> *** static library ../Security/libMgSecurity.a is not portable!
>> g++ -shared -nostdlib
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtbeginS.o
>> .libs/ServiceControllerBuild.o .libs/ServiceCoordinateSystemBuild.o
>> .libs/ServiceDataBuild.o .libs/ServiceExceptionBuild.o
>> .libs/ServiceGeometryBuild.o .libs/ServiceMapLayerBuild.o
>> .libs/ServiceNetBuild.o .libs/ServiceServicesBuild.o
>> .libs/ServiceSystemBuild.o .libs/ServiceUtilBuild.o
>> -L/usr/local/src/mapguide-1.0.1/Oem/dbxml-2.2.13/install/lib -lxerces-c
>> -lMgCoordinateSystem ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
>> ../Security/libMgSecurity.a -L/usr/lib/gcc/i386-redhat-linux/4.0.0
>> -L/usr/lib/gcc/i386-redhat-linux/4.0.0/../../.. -lstdc++ -lm -lc -lgcc_s
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtendS.o
>> /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o  -march=i386
>> -mcpu=i686 -Wl,-soname -Wl,libMgCommon.so.7 -o
>> .libs/libMgCommon.so.7.0.0/usr/bin/ld: cannot find -lMgCoordinateSystem
>> collect2: ld returned 1 exit status
>> make[2]: *** [libMgCommon.la] Error 1
>> make[2]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common/Service'
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common'
>> make: *** [all-recursive] Error 1
>> [root at user2 mapguide-1.0.1]#
>> Is it normal to have all these problems getting mapguide Open Source up
>> and running?  I am on a clean build of Fedora Core 4.
>> Thank you in advance.
>> Nick
>> Nicholas Sadowy
>> CD-Data, Inc.
>> Folsom, CA 95630
>> (916) 817-2211 x106
>> nick at cd-data.com
> http://www.nabble.com/mapguide-install-on-FC4.-tf2372882.html#a6615146
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/mapguide-install-on-FC4.-tf2372882.html#a6713634
More information about the Mapguide-users mailing list
