[mapguide-users] RE: XP Pro as MgServer?
Chris Gountanis cgountanis at mpower-tech.com
Thu Oct 12 09:53:50 EDT 2006
That happened to me when I switched from Enterprise Edition to Open Source
or the other way around. Is that something you might have done? Could be
your service is pointing to the wrong location. I basically run the server
install then IIS/PHP extensions and finally Studio (when it was free).
Chris
-----Original Message-----
From: Cory Gregor [mailto:cgregor at barkerlemar.com]
Sent: Wednesday, October 11, 2006 1:11 PM
Subject: [mapguide-users] RE: XP Pro as MgServer?
Chris,
How did you get the install to work?  It errors out on me when it try's to
start mgserver.exe at the end of the install.
Thanks,
Cory
Chris Gountanis wrote:
> Windows XP Pro SP2 and IIS is used on all our demo machines and works
> flawlessly out of the box. If you have heavy traffic on IIS you might
> want to raise the limit from 10 to 50 (50 is the max). It would not be
> used in production but great for developing and demos.
> http://www.codinghorror.com/blog/archives/000329.html
> Chris Gountanis
> Programmer/Analyst - Network Administrator cgountanis at mpower-tech.com
> T: 877-269-6971 | T: 920-830-4053 | F: 920-832-0736
> MPOWER TECHNOLOGIES
> 501 S Nicolet Road Appleton, WI 54914
> www.mpower-tech.com
> Making complex information more accessible.
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Tuesday, October 10, 2006 4:02 PM
> Subject: RE: [mapguide-users] XP Pro as MgServer?
> Yes, but it's not recommended for production use because of the
> connection limits inherent in XP.  Use a Windows Server or Linux
> product for production sites.
> If you must use XP, I would suggest using the apache/php bundled
> installation, as the IIS server in XP is limited and flaky.
> Jason
> Sent: Tuesday, October 10, 2006 13:45
> Subject: [mapguide-users] XP Pro as MgServer?
> Is it possiable to run Mapguide Server on a Windows XP machine?
> Thanks,
> Cory
> http://www.nabble.com/XP-Pro-as-MgServer--tf2419375.html#a6745023
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/XP-Pro-as-MgServer--tf2419375.html#a6761717
More information about the Mapguide-users mailing list
