[mapguide-users] RE: Am i on the Right Track?
Jason Birch Jason.Birch at nanaimo.ca
Sat Oct 14 02:44:05 EDT 2006
Didn't somebody post a code example here that did this in a generic way?  Darned if I can remember when or who...
Jason
Sent: Fri 2006-10-13 10:29 PM
Subject: [mapguide-users] RE: SPAM-LOW: [mapguide-users] RE: Am i on the Right Track?
That code was developed, in part, for a client and I do not have the
authority to give away the source code.   I can tell you the rough coding
steps:
-Grab the selection XML
-Query the original feature source using the feature ID's from the selection
XML using the FDO API
-Retrieve from the query results the key that makes sense to you and your
data
-Pass your key values to your external report
-Your external report then queries the pertinent database tables to produce
the final report
Andy
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061013/e6139962/attachment.bin
More information about the Mapguide-users mailing list
