[mapguide-users] new FDO King.Oracle provider 0.3
Jason Birch Jason.Birch at nanaimo.ca
Wed Oct 18 15:46:34 EDT 2006
Yeah, I'm psychic :)
Seriously, the earlier this gets integrated into the "official"
repository, the more testing can be done.
There are likely directory structure conventions you'll want to look at
before committing to SVN as well so that it integrates into the current
web of projects.
Will you (or someone) be setting up unit tests for this provider?
If you need a hand getting going with Tortoise (or command line) SVN,
I'm sure there are many happy to help.
Jason
Sent: Wednesday, October 18, 2006 12:39
Subject: RE: [mapguide-users] new FDO King.Oracle provider 0.3
 I suppose that was answer to my comment :)
Haris
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, October 18, 2006 9:35 PM
Seconded.  :)
It would be awesome if you could move it into the fdooracle.osgeo.org
SVN repository and it could be included in the build process...
Jason
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: Wednesday, October 18, 2006 12:32
That's great!  Do you know when we can get access to it?
RF
Sent: Wednesday, October 18, 2006 3:30 PM
Yes, right now I am using defines for name conversation from 3.1 to 3.2.
Haris
Sent: Wednesday, October 18, 2006 9:02 PM
Haris,
Do you have any plan of moving the provider to FDO 3.2 API?
RF
Sent: Wednesday, October 18, 2006 2:42 PM
Subject: [mapguide-users] new FDO King.Oracle provider 0.3
I have released new version of FDO King.Oracle provider.
Version 0.3.1 features:
*	Added support for spatial context (coordinate systems) and layer
extent
	It will report spatial context and layer extend to MapGuide.
	So when you create layer it should became visible immediatly
*	Added Filter and expression processing support
	You can set filter when query data. It can be spatial or/and
attribute filter
*	Support for all spatial query types
	EnvelopeIntersect, Intersects, Contains, Crosses, Disjoint,
Overlaps, Touches,
	Within, CoveredBy ,Inside ,Equals
*	Added support for executing any sql commands
	Using FDOISQLCommand or MgFeatureService::ExecuteSqlQuery  you
can run any sql command against Oracle database. You can read/write
spatial geometries and attributes.
*	Changed Conection properties names for Service and Username
	Bad: Existing data connections needs to be reset
	Good: Provider can be used in Autodesk Map 2007. You can use
Oracle XE with MAP
*	New connection property OracleSchema
	If it is empty than it will look in all Oracle Schemas for
spatial tables.
	If you set this then it will look in just that schema
*	Linked with new version fdo 3.1 .R70 (MG 1.0.2)
It is available at www.sl-king.com/fdooracle
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061018/9c4110e3/attachment.html
More information about the Mapguide-users mailing list
