[mapguide-users] FDO - MySQL issues/questions
Kerndata.com support at kerndata.com
Wed Oct 18 17:51:55 EDT 2006
Unexpected Error in contacting site URLBrent,
Here's a Dump of the SCHEMATA table
-- Table: SCHEMATA
CREATE TABLE `SCHEMATA`
 `CATALOG_NAME` varchar (512),
 `SCHEMA_NAME` varchar (64) NOT NULL,
 `DEFAULT_CHARACTER_SET_NAME` varchar (64) NOT NULL,
 `DEFAULT_COLLATION_NAME` varchar (64) NOT NULL,
 `SQL_PATH` varchar (512)
) CHARACTER SET utf8 COLLATE utf8_general_ci;
-- GO
BEGIN;
-- GO
-- Dumping Triggers
SET FOREIGN_KEY_CHECKS=1;
-- GO
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
Bakersfield, CA  93309
888.871.7205
888.603.6279 fax
http://www.kerndata.com
  ----- Original Message -----
  Sent: Wednesday, October 18, 2006 12:46 PM
  Subject: RE: [mapguide-users] FDO - MySQL issues/questions
  Hi Eric,
  Could you do a describe on the information_schema.schemata table and send me the results?
  Unfortunately, I don't yet have MapGuide on my machine but I tried installing 5.0.26 and accessing it with an FDO test program. I just tried a few simple things ( listing datatores, opening a connection, describing schemas ) but it worked ok.
  The main difference is that mine was a fresh install while yours would have been an upgrade from 4. I'm wondering if the information_schema ends up a bit different in either case.
  Brent.
  -----Original Message-----
  From: Kerndata.com [mailto:support at kerndata.com]
  Sent: Tuesday, October 17, 2006 7:59 PM
  Subject: Re: [mapguide-users] FDO - MySQL issues/questions
  Brent,
  I upgraded to 5.0.26-max and now I receive:
  "An exception occured in FDO component.
  RDBMS:"
  and then:
  "No data stores found."
  Is there some other item I'm not understanding here?
  Please advise,
  Eric Brown
  Kerndata.com
  5500 Ming Avenue
  Suite 160
  888.871.7205
  888.603.6279 fax
    Sent: Tuesday, October 17, 2006 3:01 PM
    Subject: FW: [mapguide-users] FDO - MySQL issues/questions
    MySQL 4.1.20 would be older than the minimum version supported by the MySQL provider. I'm not exactly sure what the minimum is (does anyone else know off-hand?). However, upgrading to 5.0.15 or later would get rid of the error.
    The MySQL provider relies on some information_schema tables (which were introduced in version 5) to get information on tables, columns, etc.
    From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
    Sent: Tuesday, October 17, 2006 3:35 PM
    I believe that the MySQL provider requires that a schema be defined, though I haven't tried it myself.
    Currently, the only way that I know of for doing this is via Autodesk's Map 3D.  The scripts for creating the schema tables are in FDO repository I think, so you might be able to reverse engineer the process and create your own.
    https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/com/
    Jason
    Sent: Tuesday, October 17, 2006 10:18
    Subject: [mapguide-users] FDO - MySQL issues/questions
    I'm attempting to configure a MySQL connection in MapGuide Studio 2007 using the MySQL FDO I downloaded and installed from osgeo.org.
    It appears that the "Test Connection" functions properly (I think) but the little box that shows whatever message it's supposed to show doesn't show a message - just a little yield sign with no message in the box (on user permissions errors I receive an actual message).
    At any rate, when I ultimately enter the correct connection information and attempt to browse for a Data store - I receive the following message:
    "An exception occurred in FDO component.
    RDBMS: Table 'information_schema.schemata' doesn't exist"
    And then -
    "No data stores found"
    Any insight into this error - or how to actually connect to my MySQL db would be greatly appreciated.
    DB = MySQL 4.1.20
    Please advise,
    Eric Brown
    Kerndata.com
    5500 Ming Avenue
    Suite 160
    888.871.7205
    888.603.6279 fax
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061018/2657b6e3/attachment.html
More information about the Mapguide-users mailing list
