PHP version
Kencana bluesky_dyx at hotmail.com
Thu Oct 19 02:25:15 EDT 2006
hi jason,
I have try to apply the code into sheboygan map, but when i ran it the
symbol didnt show.
it gave me such error message as i have attach in the image..
I hope you can give me your guidance.
I am looking forward for your reply and thank you
Regards,
Kencana
Jason Birch wrote:
> There are quite a few developer resources that will help you get started
> with your quest to place a point on the map (and beyond).
> First, load the Sheboygan sample and the Php Sample App from the Downloads
> page.  At least two of the samples in the PHP app include placing
> pushpins.  These are located at the bottom of this page:
> https://mapguide.osgeo.org/downloads.html
> <https://mapguide.osgeo.org/downloads.html>
> under the heading "Samples for MapGuide Open Source 1.0.x".  Ignore the
> .Net and Java sample apps.
> Next, download the Developers Guide (PDF version is best) and the sample
> code from the Documentation page:
> https://mapguide.osgeo.org/documentation.html
> <https://mapguide.osgeo.org/documentation.html>
> Finally, visit this site, for some more advanced developer examples (with
> links to source code):
> http://data.mapguide.com/mapguide/devguide/index.php
> <http://data.mapguide.com/mapguide/devguide/index.php>
> and it looks like Andy still has an unofficial copy of those samples for
> download available here:
> www.spatialgis.com/devguide_june_2006_samples.zip
> Jason
> ________________________________
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Wed 2006-10-18 6:49 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: RE: RE: PHP version
> Hi Jason,
> I have reinstall everything and now everything works perfect. thanks for
> your guidance.
> By the way, do you know how to adding symbols(pin point) on to the map?
> can I know what are the step. I am learning on it using php as the
> development tools now .
> I am looking forward for your reply and thank you once again.
> regards,
> Kencana
> Jason Birch wrote:
>> The first links (the tar files) are source code.  You need to install
>> the executable packages which are a bit further down the list.
>> If you can't log into the administrator, then there's definitely
>> something wrong with your installation.  Let us know when you get the
>> old version uninstalled and 1.0.2 installed.  In your case, you will
>> likely want to choose IIS integration.
>> Jason
>> -----Original Message-----
>> Sent: Wednesday, October 18, 2006 02:12
>> Subject: [mapguide-users] RE: RE: PHP version
>> Hi Jason,
>> I guess I have install the old version of mapguide. first of all sorry
>> if I am troubling you. can I know the step of installing the opensource
>> 1.0.2?I download tar file for that. but I am confused in how to install
>> it.
>> currently I am using windows server 2003. I am not able to log in into
>> map administrator, where it didnt show anything only blank page.and I am
>> trying to view the shebboygan map but it shows nothing. I am looking
>> forward for your reply.
>> Regards,
>> Kencana
>> Jason Birch wrote:
>>> It's difficult to troubleshoot your problems with the level of details
>>> you're providing.
>>> What version of MapGuide are you trying to install?  I would suggest
>>> starting with MapGuide Open Source 1.0.2, as it has a much cleaner
>>> installation than any of the earlier versions.  Either that or waiting
>>> for the SP1 from Autodesk.  There are known issues with some locales
>>> in earlier versions of MapGuide.
>>> What operating system are you running?
>>> Are you able to login to the Map Administrator?
>>> Are you able to login to mapguide/mapagent/index.html and get a value
>>> for the EnumerateResources query?
>>> Where are you unable to see the map?  In Studio?  In the sample
>>> application?
>>> What data are you looking at?  Sheboygan?  Your own data?
>>> Is there any other information you can provide that could help with
>>> the resolution of this problem?
>>> Jason
>>> Sent: Tue 2006-10-17 11:40 PM
>>> Subject: [mapguide-users] RE: PHP version
>>> Hi Jason,
>>> Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
>>> config.
>>> But when i try to view the map it shows nothing. I have follow the
>>> installation instruction bt still nothing.
>>> I hope you can give me solution. I am looking forward for your reply
>>> and thank you.
>>> Regards,
>>> Kencana
>>> Jason Birch wrote:
>>>> MapGuide Open Source (and I believe Enterprise) are reliant on PHP
>>>> version 5.0.5.
>>>> At least, that was the case last time I checked (several users have
>>>> found this out by running with newer unsupported versions of PHP) and
>>>> PHP 5.0.5 is the version which is bundled with MapGuide.
>>>> Jason
>>>> Sent: Tue 2006-10-17 9:35 PM
>>>> Subject: [mapguide-users] PHP version
>>>> Hi guys,
>>>> I am new to this "Autodesk Mapguide 2007" and I want to ask about the
>>>> php version which compatible to this software. I am looking forward
>>>> for the reply and thank you very much.
>>>> Regards,
>>>> Kencana
>>>> View this message in context:
>>>> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
>>>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>>> http://www.nabble.com/PHP-version-tf2464139.html#a6870320
>> http://www.nabble.com/PHP-version-tf2464139.html#a6872289
> http://www.nabble.com/PHP-version-tf2464139.html#a6889237
http://www.nabble.com/file/3746/point.JPG
http://www.nabble.com/file/3746/point.JPG point.JPG
View this message in context: http://www.nabble.com/PHP-version-tf2464139.html#a6891254
More information about the Mapguide-users mailing list
