[mapguide-users] RE: FDO King.Oracle provider 0.3
Haris Kurtagic haris at sl-king.com
Fri Oct 20 13:05:50 EDT 2006
Are you using Autodesk MapGuide Studio - list should be easy editable in
it :).
Haris
-----Original Message-----
Sent: Friday, October 20, 2006 7:03 PM
Subject: [mapguide-users] RE: FDO King.Oracle provider 0.3
I got that. I did read the readme before I started this, I promise :)
My problem is that I literally can't figure out how to edit the property
list.  I am sure my brain is just running slow or something. But, how do
I specify these connection properties? Should the list be editable,
because it isnt. Do I have to put these properties in the "configuration
file"  What is the format of that file?
haris kurtagic wrote:
> Hi,
> there should be four properties:
> Username - you enter username to connect to Oracle ( oracle user you
> created in database ) Password - password of user Service - this is
> service name for Oracle database, depends of type of client and
> configuration
>           for example for xe you can enter: //localhost/xe
> 	    or tns name if you configured it in your oracle client
software
>           there is more in readme.txt on download page
> OracleSchema - leave it empty and it will show all spatial tables, or
> you enter Oracle schema name and you got tables just from that schema.
> If I wasn't clear enough, please ask again :)
> Haris
> From: Joel Carranza [mailto:jec at gatekeeper.com]
> Sent: Friday, October 20, 2006 6:20 PM
> Subject: [mapguide-users] FDO King.Oracle provider 0.3
> I have downloaded and installed the new Open Source v1.0.2 release of
> MapGuide, along with the King.Oracle FDO. FDO shows up in my list of
> providers, but when I get to the "Configure Feature Resource using
> Generic Editor" screen, I can't figure out how to specify my
> connection properties.
> There is a list in the window with Property/Value pairs, but I can't
> seem to figure out how to edit that list.
> Am I missing something obvious here?
> Thanks
> Joel
> http://www.nabble.com/FDO-King.Oracle-provider-0.3-tf2481642.html#a692
> 01
> 21
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
http://www.nabble.com/FDO-King.Oracle-provider-0.3-tf2481642.html#a69209
60
More information about the Mapguide-users mailing list
