[mapguide-users] King.Oracle 0.3.3
Joel Carranza jec at gatekeeper.com
Tue Oct 24 14:37:18 EDT 2006
Another problem I am having. Not sure if this is a problem with the FDO
itself or not. With one of my test sites,  my coordinate system does not
show up when a create a map. If I try to choose a map, I get an error about
failure to convert. I leave the map coordinate system blank, and the map
still renders, but I just wanted to rule this out as a source of bad
performance
Using the mapagent, I get the following results back on the resulting
spatial context.
Coordinate System API: CheckWkt
OGC WKT:
PROJCS["Ohio 3401, Northern Zone (1983, US Survey feet)", GEOGCS ["NAD 83
(Continental US)", DATUM ["NAD83 (Continental US)", SPHEROID ["GRS 80",
6378137, 298.257222101]], PRIMEM [ "Greenwich", 0.000000 ], UNIT ["Decimal
Degree", 0.01745329251994330]], PROJECTION ["Lambert Conformal Conic"],
PARAMETER ["Standard_Parallel_1", 40.433333], PARAMETER
["Standard_Parallel_2", 41.700000], PARAMETER ["Central_Meridian",
-82.500000], PARAMETER ["Latitude_Of_Origin", 39.666667], PARAMETER
["False_Easting", 1968500.000000], UNIT ["U.S. Foot", 0.3048006096012]]
Status:
Pass
Coordinate System API: ConvertWktToCoordinateSystemCode
OGC WKT:
Code:
Status:
Fail
Error:
The coordinate system conversion failed. Could not determine OGC WKT from
the code.
Is there some additional config I need to do somewhere, or is this a bug?
Joel
haris kurtagic wrote:
> Hi,
> newer version of King.Oracle 0.3.3 provider:
> *	Support for Spatial Views
> 	It will display views based on spatial tables. Views needs to be
> added into sdo_geom_metadata for provider to find them.
> Get it here: www.sl-king.com/fdooracle
> Haris
View this message in context: http://www.nabble.com/King.Oracle-0.3.3-tf2500627.html#a6978902
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide-users mailing list
