[mapguide-users] WMS DEMO HELP
Thomas M. Tuerke thomas.m.tuerke at autodesk.com
Tue Oct 24 19:26:57 EDT 2006
Couple of questions/suggestions concerning your installation.
1. Have you run the WMS configuration in Site Admin page?  This is configured for "localhost:8008" out of the box, but if you're making the server outward-facing, the server name and port will need to be set there.
If your request=GetCapabilities fails, this is probably the reason why.
2. Have you used Studio or the web equivalent to publish the desired layers?
If your request=GetCapabilities succeeds, but the capydoc is "empty" (no published layers) this is probably the reason why.
3. Have the desired layers been populated with correct metadata?  Bounds is the one that's most important, but other information helps.
If your request=GetMap returns an exception concerning SRS, this is probably the reason why.
That should get you started.
-----Original Message-----
Sent: Tuesday, October 24, 2006 3:19 PM
Subject: [mapguide-users] WMS DEMO HELP
Hello people!  Does anyone have WMS working with Mapguide Enterprise or
Mapguide open source?  Is it possible to try it out?  Are there any words of
advice to make it work?  So far we have had no luck exposing map layers to
WMS or viewing WMS.  Any direction is welcome!
View this message in context: http://www.nabble.com/WMS-DEMO-HELP-tf2504519.html#a6982682
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
