[mapguide-users] King.Oracle 0.3.3
Andy Morsell amorsell at spatialgis.com
Tue Oct 24 23:54:35 EDT 2006
I agree that with MapGuide 6.5, Oracle Spatial is nearly as fast as SDF.
Nothing beats SDF, however.  It's hard to say with the current versions of
MGOS and the King provider since I doubt that anyone has bench marked it
against SDF+ to date, but I would ultimately expect similar performance.
The same goes for the Autodesk Oracle Spatial FDO provider: I expect that
the improvements that Autodesk are making to it will bring it more back in
line with performance of MapGuide 6.5.  I saw a beta version of the patched
provider about a month ago, and my tests indicated that it will be much,
much better than the current version.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, October 24, 2006 6:18 PM
Subject: RE: [mapguide-users] King.Oracle 0.3.3
I'm not sure about performance comparisons, but I've always liked the idea
of displaying my data directly from its source.  In my case it's Oracle
Spatial.  I'm not one for file maintenance and making sure the data from
Oracle Spatial is being brought over and converted into an SDF for Mapguide
to read.
In terms of the previous Mapguide 6.x versions, SDF was always the fastest
in terms of displaying data in Mapguide.  But that's not to say that
displaying data from Oracle Spatial was slow.  With some tuning and
tweaking, Mapguide 6.x displayed data from Oracle Spatial superbly.  That's
one of the reasons we chose to go with Mapguide.
I just hope Enterprise/MGOS gets to the that level one day.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject
to the Public Records Law of Florida.
  _____
From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
Sent: Tue 10/24/2006 8:47 PM
Subject: Re: [mapguide-users] King.Oracle 0.3.3
Several people have indicated excellent performance.  I have no
experience with Oracle so I am curious if anyone has comments on
performance relative to SDF?  Faster/slower?  Conditions under which
it is faster/slower?
Cheers
Paul
On 24-Oct-06, at 6:28 PM, Haris Kurtagic wrote:
> I am getting this after login as Anonymous:
> An unclassified exception occurred. Exception occurred in method
> MgWebLayout.ParseWebLayoutDefinition at line 294 in file c:
> \build_tux_area\mgdev\web\src\webapp\WebLayout.cpp
> Haris
> Sent: Tuesday, October 24, 2006 11:19 PM
> Haris:
> I'm seeing some other strange things.  The labels on some of my
> polygons have odd characters in them.  Not sure where these are
> coming from.
> http://gis.co.pinellas.fl.us/mapguide/mapviewerajax/?
> WEBLAYOUT=Library%3a%2f%2fPinellas%2fLayouts%
> 2fkingtest.WebLayout&LOCALE=en
> Use Anonymous for the user and zoom into a scale of at least 10,000
> to pull up the parcels.  Then hover over one of them.   The
> performance for these coming up is great.
> I'm just stumped on why the Evacuation Routes are not displaying
> with the parcels.  Same coordinate system in the database.  The
> layer previews fine too.  I can see them when editing the layer
> style; just can't see them when I place the layer in the map.
> GIS Applications
> is subject to the Public Records Law of Florida.
> From: Haris Kurtagic [mailto:haris at sl-king.com]
> Sent: Tuesday, October 24, 2006 4:43 PM
> Hi Juan,
> I am looking at this memory usage.
> Which version of MG are you using ?
> Haris
> Sent: Tuesday, October 24, 2006 10:26 PM
> True.I was thinking about it.  I would just need to construct the
> GEOMETRY in the view.   I'll try it out.
> Thanks.
> GIS Applications
> Sent: Tuesday, October 24, 2006 3:31 PM
> I would suspect it is a memory leak in provider. I will check it.
> "I just wish I could use this for non Oracle Spatial tables with
> coordinate fields" - you mean like displaying points from x,y
> columns ?
> Beside suporting it in provider, one of the ways could be to create
> a view in Oracle for it.
> Haris
> Sent: Tuesday, October 24, 2006 7:52 PM
> Haris:
> I'm testing this now and it seems that your provider is pulling up
> the spatial data much faster.  The only problem that I'm running
> into is the server process is eating up memory at a large clip when
> adding more layers from Oracle.  It's gotten up to over a GIG.
> I've had to shutdown Mapguide server completely and then restart
> it.  The memory usage will go back up as I interact with more
> Oracle spatial layers.  Not sure if it's more on the Mapguide
> server side or the provider.
> coordinate fields.  The ODBC provider will not show tables for me.
> GIS Applications
> Sent: Tuesday, October 24, 2006 7:17 AM
> Subject: [mapguide-users] King.Oracle 0.3.3
> Hi,
> newer version of King.Oracle 0.3.3 provider:
> Support for Spatial Views
> It will display views based on spatial tables. Views needs to be
> added into sdo_geom_metadata for provider to find them.
> Get it here: www.sl-king.com/fdooracle
> Haris
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061024/55319b1e/attachment.html
More information about the Mapguide-users mailing list
