[mapguide-users] King.Oracle 0.3.3
    Andy Morsell
    amorsell at spatialgis.com
    Tue Oct 24 23:57:40 EDT 2006
I'm unable to access it as well.  I get the same error message.
Andy
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, October 24, 2006 6:10 PM
Subject: RE: [mapguide-users] King.Oracle 0.3.3
Haris:
Are you still getting the error?   I'm at home now and I'm able to pull it
up.   Please let me know...Maybe it's one of those oddities about
Enterprise.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject
to the Public Records Law of Florida.
  _____
Sent: Tue 10/24/2006 6:28 PM
I am getting this after login as Anonymous:
An unclassified exception occurred. Exception occurred in method
MgWebLayout.ParseWebLayoutDefinition at line 294 in file
c:\build_tux_area\mgdev\web\src\webapp\WebLayout.cpp
Haris
  _____
Sent: Tuesday, October 24, 2006 11:19 PM
Haris:
I'm seeing some other strange things.  The labels on some of my polygons
have odd characters in them.  Not sure where these are coming from.
http://gis.co.pinellas.fl.us/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2f
%2fPinellas%2fLayouts%2fkingtest.WebLayout
<http://gis.co.pinellas.fl.us/mapguide/mapviewerajax/?WEBLAYOUT=Library%3a%2
f%2fPinellas%2fLayouts%2fkingtest.WebLayout&LOCALE=en> &LOCALE=en
Use Anonymous for the user and zoom into a scale of at least 10,000 to pull
up the parcels.  Then hover over one of them.   The performance for these
coming up is great.
I'm just stumped on why the Evacuation Routes are not displaying with the
parcels.  Same coordinate system in the database.  The layer previews fine
too.  I can see them when editing the layer style; just can't see them when
I place the layer in the map.
GIS Applications
  _____
Sent: Tuesday, October 24, 2006 4:43 PM
Hi Juan,
I am looking at this memory usage.
Which version of MG are you using ?
Haris
  _____
Sent: Tuesday, October 24, 2006 10:26 PM
True.I was thinking about it.  I would just need to construct the GEOMETRY
in the view.   I'll try it out.
Thanks.
GIS Applications
  _____
Sent: Tuesday, October 24, 2006 3:31 PM
I would suspect it is a memory leak in provider. I will check it.
"I just wish I could use this for non Oracle Spatial tables with coordinate
fields" - you mean like displaying points from x,y columns ?
Beside suporting it in provider, one of the ways could be to create a view
in Oracle for it.
Haris
  _____
Sent: Tuesday, October 24, 2006 7:52 PM
Haris:
I'm testing this now and it seems that your provider is pulling up the
spatial data much faster.  The only problem that I'm running into is the
server process is eating up memory at a large clip when adding more layers
from Oracle.  It's gotten up to over a GIG.   I've had to shutdown Mapguide
server completely and then restart it.  The memory usage will go back up as
I interact with more Oracle spatial layers.  Not sure if it's more on the
Mapguide server side or the provider.
fields.  The ODBC provider will not show tables for me.
GIS Applications
  _____
Sent: Tuesday, October 24, 2006 7:17 AM
Subject: [mapguide-users] King.Oracle 0.3.3
newer version of King.Oracle 0.3.3 provider:
*	Support for Spatial Views
It will display views based on spatial tables. Views needs to be added into
sdo_geom_metadata for provider to find them.
Get it here: www.sl-king.com/fdooracle
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061024/a6b27e19/attachment.html
More information about the Mapguide-users
